Beckster's M52 325IS
  • 2002jm
    • Sep 2005
    • 2076
    #106
    this weekend?
    Will we see this car this weekend?
    jm
    • BECKSTER
      • Jun 2015
      • 667
      #107
      jm
      Unfortunately not, I'm still waiting to get my harness back and I need to order adapters for the wheels.
      If there is a C&C in September, i'll be at that one.
      1990 Alpine 325is
      1992 Schwarz 325ic (sold)
      • BECKSTER
        • Jun 2015
        • 667
        #108
        I'm withholding
        I got around to putting on my adapters from Mushi, and rolling my rear fenders, (thanks for the roller "Big Willy.")
        215/45 with 18mm adapters = super sexy stants.
        I have more updates for you, so stay tuned.
        1990 Alpine 325is
        • BECKSTER
          • Jun 2015
          • 667
          #109
          Welded the oil pump nut and threw the e34 pan up.
          Ended up mating the g260 along with the lightened flywheel, spec stage 2 clutch.
          But I forgot the pilot bearing so I pulled the motor out.
          I threw a new pilot bearing inside, but before I did I decided to do a bit of shaving and repainting.
          Motor waiting to go in, I cleaned up the transmission and wrapped the headers too.
          Motor sitting in on condor 24v swap mounts, and custom mount spacers I made.
          M52 throttle body to m50 manifold metal gasket.
          More updates coming soon.
          1990 Alpine 325is
          • ST1G
            • Oct 2012
            • 6689
            #110
            215/45 with 18mm adapters = super rub a dub dub all the time.
            • BECKSTER
              • Jun 2015
              • 667
              #111
              Way to be a debby downer.
              1990 Alpine 325is
              • BECKSTER
                • Jun 2015
                • 667
                #112
                I finally buttoned up all my wiring, and started the car.
                Having my harness modified by Kadunza was definitely a game changer.
                Welded up my 2nd o2 sensor because I couldn't fit it on the header bung.
                (the welds are crappy, but they work.)
                My Dad welded up the rest of the exhaust and everything looks great.
                Specs are full 2.5' piping with eBay headers, aero resonator, and a gutted cat.
                Here is how it sounds https://www.youtube.com/watch?v=DqNXSfCDEJI
                All I have left to do is
                - finish mounting my skidplate.
                - bleed clutch and brakes.
                - bleed power steering.
                1990 Alpine 325is
                • sam_
                  • May 2014
                  • 630
                  #113
                  ooo very nice
                  1991 325i
                  flickr
                  @sambhaskins
                  • BECKSTER
                    • Jun 2015
                    • 667
                    #114
                    Originally posted by sam_
                    ooo very nice
                    Thanks babe
                    1990 Alpine 325is
                    • BECKSTER
                      • Jun 2015
                      • 667
                      #115
                      Well its done, I didn't exactly get it fully functional before my 18th birthday but I almost met the deadline.
                      Other updates include an eBay mishimoto rad, e30 m3 fan switch, and a few other goodies you all should stay tuned for.
                      1990 Alpine 325is
                      • BECKSTER
                        • Jun 2015
                        • 667
                        #116
                        I went for my first drive tonight and I'm very stressed out now.
                        I drove like a grandma for 2-4 miles and then I started giving it some gas, and I did 2-3 easy downshifts and the clutch was slipping.
                        It is a SPEC stage 2, lightened/resurfaced flywheel, new TOB and pilot bearing.
                        Should I drive it like a grandma for a few hundred miles and see if that helps seat the clutch to the flywheel properly or have I toasted my clutch?
                        1990 Alpine 325is
                        • sam_
                          • May 2014
                          • 630
                          #117
                          Perhaps you have a leak that could have completely soaked the clutch?
                          1991 325i
                          flickr
                          @sambhaskins
                          • Northern
                            I like cupcakes & sh!tboxes
                            • 5280
                            #118
                            Maybe something clutch/pp defective? or maybe wrong TOB/slave/something that won't let the clutch engage all the way?
                            Going to need to rip it apart anyway, may as well get it over with now and fix the problem before it gets worse.
                            Originally posted by priapism
                            Originally posted by shameson
                            • BECKSTER
                              • Jun 2015
                              • 667
                              #119
                              I've put about 150 miles on the car and almost all the slipping went away.
                              It just slips very very very slightly in 5th gear at high rpms.
                              I think it's breaking in.
                              1990 Alpine 325is
                              • e30austin
                                • 15382
                                #120
                                You'll need to do 500 very easy miles...I already told you this, son! Those SPEC clutches must be broken in properly.
