Another red convertible
    Hey there! Finally decided to make a build thread as I feel my car is almost up to the challenge of showing off on the internet.
    There are a lot of brilliantrot red verts on the roads. My goals for the car are to be super clean and real simple. Minimal performance upgrades and no slammed suspensions.
    A bit of history on the vehical I am the second owner of the car. Originally owned by a doctor in Kentucky. I picked the vehicle up from his wife after his passing. Partially this is one of the reasons I do not want to overly molest the car; To pay homage to the original owner who kept the car in fine shape.
    Some before photos
    So I had an 06 S4 along with my E34 rally car. The S4 was my daily. Just my luck a semi truck ran out of room and ran me over. Hit and run too! Was a 'fun' experience but left me without a car payment and a car...
    Found this girl on the net and picked her up for the low of $4000
    Low miles 104k, all stock, garaged car.
    Since then the following has been done. You may notice there is no water pump replacement that is because I had that service performed at a shop before I drove the car to its new home (no since in risking that on first trip)
    [SIZE="1"]Silicone radiator hoses
    Pedals
    Aluminum Radiator
    Brake Kit;rotors,pads,lines
    spark plug -ngk
    air filter
    glove box latch
    oil filter
    valve cover gasket
    Ignition coil
    ignition rotor
    distributor cap
    cabin air filter
    Spark plug wire - performance
    Oil change
    Intake Boot - Air Flow Meter to Throttle Housing
    TPS
    Air Hose from Idle Control Valve
    Throttle Housing Gasket
    Breather Hose
    Valve cover Gasket Reinz
    Oil change, valve adj, gasket,
    Hardtop
    M-tech 1 front lip
    Front spoiler retaining clips
    M Oil cap
    hose clamps for radiator hoses
    Oil filters
    DEPO Euro Smiley Projector headlights -set
    Kosei K1 Wheels w/ tires 15x8 et20
    O-Ring - Shift Rod Joint
    Dowel Pin for Shift Rod Joint
    Shim for Manual Trans Selector Rod (10.2 X 16 X 0.9 mm) (Yellow)
    Shift Rod Joint - Manual Transmission
    Shift Rod Circlip - Shift Rod Joint and Shift Lever
    Bushing - Manual Trans Shift Lever Pivot to Support Arm
    Shift Lever
    Rocker Shaft Plug In Head
    Spark Plug - Bosch WR-8-LC+
    Copper Washer - 12 X 17 X 1.5 mm - Oil Pan Drain Plug
    Engine Oil Drain Plug (12 X 1.5 mm)
    Hood Shock
    Trunk Shock
    Belt - A/C Compressor 13 X 810
    Belt - Power Steering 10 X 825
    Belt - Alternator 10 X 965
    5mm 4x100 57.1cb Spacers
    57mm Silver Stud 5-Lug Kit 12x1.5
    cocomats floor mats
    Kenwood radio with floorcolor matching iphone cord
    This is where she sits now.
    One of my favorite add-ons would be the cocomats.com custom floor mats. very expensive but give the car a really cool custom look to the interior.
    To do:
    new seat leather
    Koni yellows
    Full miller bolt on performance package
    Wood grain wheel and shift knob (lots of options to choose)
    Power steering refresh
    Find a set of Apex arc-8s 17x8
    I'm handy with a camera and she is one of my favorite models. Instead of posting bunch of pictures here is a link to a google album
    The photos are in chronological order so you can see what gets added over time.
    Updates to continue as the with the build.
    02/1992 E30 Cabrio
    02/1989 E34 535iS
    Good looking car! This is a classy looking ride so I'm not sure Apex wheels will compliment them as a good set of weaves...imho.
    COTM
      Wheels look gross... Out of place on an otherwise nice vert.
      ACS S3 Build / Dinan 5 E34
        Looks great, Reminds me of my own red e30 vert!
          Is that a 318i? I noticed you didn't list the timing belt. That's def something you want to replace if it's a 325i. 4k is a great deal for a plastic bumper one owner convertible with a hardtop. Sounds like you got quite the bargain
          I would suggest H&R springs/koni shocks to help relieve that front wheel gap
          And the koseis, while normally a great wheel, don't really do "stock" that well. And for some reason they always look better on hardtops..
          Still, nice car and hope to see what you do with it!
            I agree with the wheels they could be better. I like the extra inch of tire the Kosei's afford me. TBH I have had an influx of money due to an illness which prevents me from eating out at restaurants and going to bars (So basically the best parts of life besides cars). The extra scratch usually gets used for things like "$400 set koseis with tires". Its all I have to do to keep myself ocupied HA
            Timing belt was done with water pump when I first bought it. The list is stuff I have done to it via my hands
            02/1992 E30 Cabrio
            02/1989 E34 535iS
              As another red cabrio owner...actually I'm not red, the car is....I'm sitting here thinking.....what would an S4 engine do for an e30 :)
              Alice the Time Capsule
                Love your car, Andrew! Sooooo clean!
                Originally posted by LJ851
                kingston is the play by play announcer for this thread.
                ‘Tis by the grace of God that my cars run!
                Originally posted by unloadedak
                #teamross
                Siobhan's Build Thread - UPDATED!
