Eleanor the alpine 318is
  • sandrune
    • Sep 2014
    • 87
    I've been meaning to start one a build thread for a while now. Just never found time to put one together but now I'm finally getting to it!
    Throughout highschool I had a love for e30s and wanted one as my first car. However my parents got a deal from a family friend on a cheap car no ones ever heard of. A Suzuki esteem. Ive literally never seen another one haha. It lasted me throughout highschool and into my second year of college before the transmission went out. The hunt for my e30 began.
    I wanted a manual, alpine white, two door, late model, 318, with relatively low miles. Months searching and I finally found one for sale. A 91 318is. I researched what to look for when buying one of these. My father and I went to see it.
    None of the problem areas had any problems. He had supposedly rebuilt the engine, it had a spare bucket seat, a recap, and a nardi wheel. I was hooked. He wanted 4,200 for it but we talked him down to 3,500 because the door had bad paint, the mileage was just shy of 200k , a window motor was going out, and the rear seat was missing. My father test drove it and drove it home as I had only had one lesson in driving stick.
    Before my dad let me drive it on my own he wanted to ride with me. We hopped in and I drove it with no problems, way Better then I drove his 91 honda civic.
    First thing I wanted to do was put in new seats and seat belts. I found seat belts at pick a part and put them in. Of course I shorted out the car as I crimped a wire from the battery blowing s relay and an online fuse. One week and I already broke the car haha. Fix that and then track down some seats. The seller recognized my car and led me to its old build thread. Found here. http://www.r3vlimited.com/board/showthread.php?t=219821
    So now I knew what had been done to the car.
    Needed a new cat to pass smog tester said engine was in excellent condition for its age and mileage.
    I then picked up some new emblems
    No issues for a while until school started again and the roads were horrid. As the engine is an m42 the pan is low and as the car was slammed my pan sat around an inch from the ground I broke my oil pan to many times...4 times to be exact...course I blame my girlfriend at the time for the horrible roads to her college.
    At local meets I was known as the oil pan man and was always asked what number I was on.
    I finally decided to raise the car. I picked up some eibach lowering springs at a meet, which had a limbo contest ended up third lowest. Was a fun last hurrah before I raised the car.
    Got an is lip with splitter and some skirts off a Taurus to help visually lower the car since I raised it about 4 inches
    Cleaned out the garage for a flat place to work on the car
    Needed new tires as mine had wore to the inner belts got some toyo proxes r1r to go on my 949 6ul wheels. Front wheels are 15x9 with 195/50 rears are 15x10 with 205/50
    Then on a trip to big bear for my girls birthday my heater core burst. Got towed home and bypassed the core. Then decided to redo the coolant system. So new radiator, water pump, fan clutch, thermostat, and fan temp switch.
    Still have the core bypassed. No AC or heat sucks but oh well.
    Took a trip up to the snow
    Christmas I got new headlights, a csb since mine was non existent and a new did bushing. Also some tools too
    Went in to change the oil filter housing gasket and o ring as they were leaking. Then found my alternator which I had already replaced once had cracked.
    Parking at school was horrendous and often had to longboard to it from a neighborhood so I designed a rack for it and had my dad lazer cut it out at his machine shop and had one of his welders fashion it to my rear strut bar. I then also threw in some wood paneling since the trunk had been stripped bare
    I now also have the side carpeting in the trunk also. Looks real sharp.
    Then I noticed some clunking when turning. I started to investigate and noticed the passenger side motor mount had completely broken free from the surface and was resting on the steering rack. Ordered a reinforcement kit from garagistic to have our shops welders fix the subframe
    Since I was dropping the subframe I decided to redo the front suspension. Ordered the suspension kit from CA tuned that came with control arms, CABs, end links, and tie rods.
    I also had been having an issue with my injectors. I figured they were leaking since my mileage was garbage and I was getting gas In The oil. So I pulled those and got new ones also picked up the coolant temp sensor that goes to the ecu in hopes it might help the gas mileage. Was told if it's bad the engine doesn't realize it's warmed up yet and constantly runs rich.
    Also figured I should redo my valve cover gasket as well. And since both the intake manifold and valve cover was off I sent them off to get powder coated. also sent in the oil filter cap. Still haven't put them on as the engine is still hanging from this and I don't want to scratch them
    I then also finally decided to do my csb and diff bushing too. One bolt on the drive shaft wouldn't come loose and I ended up stripping it so I grinded it off. I got the drive shaft out and finally saw the condition of the csb literally non existent.
    I ordered some new motor mounts since mine were shot and then some engine spacers from condor speed shop to raise the oil pan up so I can drop the car again on my old springs I kept
    Right now I'm still in middle of swapping the old springs in, waiting for the motor mounts and new drive shaft bolts and nuts to come in so the car is sitting like this
    I'll post pictures once I get it back on the ground and running. Plan on sea foaming it afterwards too just to rid all the gunk out that I figure is in there from the look of the injectors.
    Sent from my HTC6535LVW using Tapatalk
    '91 318is
  • sandrune
    • Sep 2014
    • 87
    Oh god auto correct got me haha. A sparco bucket seat and a recaro*
    '91 318is
    • 2mAn
      Señior Mod
      • 21067
      Hey, thought I recognized this car. I sold you my friends' taurus side skirts. car looks good
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • spiDmang
        • 3941
        Looks nice!
        91' 318iS - S54/6MT Swapped
        08' E90 M3 6MT - Daily
        Originally posted by IronJoe
        Originally posted by 2mAn
        • sandrune
          • Sep 2014
          • 87
          Haha yeah you did! Only thing is one of those fell off on the free way...so I went and pulled some new ones from pick a part haha
          '91 318is
          • Gkwan
            • Sep 2015
            • 82
            Awesome build! If you don't mind me asking, which injectors are those? I need to upgrade mine too.
            Keep the updates coming!
            • sandrune
              • Sep 2014
              • 87
              Thanks man! I'll keep the updates coming as often as I can. Should be a few the week alone as I'm putting the car back together now. The injectors are Nothing special. Just looked them up on oriellys. They were a mid range price and I wasn't looking for any higher lb fuel injector. Here's a link to them
              http://m.oreillyauto.com/h5/r/oap/si...tor&reset=true
              I can't tell you how they are as they still aren't technically in the car yet. But I figure they're 100x better than the crud covered ones I had
              '91 318is
              • sandrune
                • Sep 2014
                • 87
                Just got the new motor mounts from BMW and also the bolts I needed for the drive shaft.
                Here's the spacer from condor speed shop installed on the motor mount
                Now I can start putting it all back together
                '91 318is
                • Anthony B
                  • Nov 2012
                  • 308
                  Looks like a good start mate, will be good to see your progress
                  • sandrune
                    • Sep 2014
                    • 87
                    Time to change the center console fluid. haha but really I'm doing the tyranny fluid.
                    also got the sub frame and motor mounts up yeah I know I've got an oil leak. Just haven't really looked into from where...
                    Also put the CABs on backwards and am hating myself for it. But once I swap them the right way I can get the car off Jack stands and then put the motor back together.
                    '91 318is
                    • sandrune
                      • Sep 2014
                      • 87
                      Anyone know what this may be? Found it hanging free under the dash.
                      '91 318is
                      • sandrune
                        • Sep 2014
                        • 87
                        Got the engine back together last night. Looks phenomenal. I'm in love with it haha I'm only afraid that the engine might not clean the hood now because of the spacers but I guess we will see.
                        turned her over and she started right up but then stalled. Heard little bubbles from around under the manifold. Think one of my fuel rail hoses didn't seat properly so it's not getting the pressure it needs to stay running. I'll go in and fix that tonight.
                        Also still need to put in the steering rack and tie rods as well as put the CABs on right. After that she's good to go!
                        '91 318is
                        • alas
                          • Oct 2015
                          • 291
                          Nice! Keep it up :)
                          -E
                          -ALaS
                          • sandrune
                            • Sep 2014
                            • 87
                            Got my shift boot set from Matt-b installed today really like how they turned out! Great quality from Matt!
                            Next for The interior is a shift knob and hopefully a renown wheel that will tie into these boots!
                            Also wanting to re dye my passenger recaro seat it's all faded and stained anyone know what model it is? Or if it even is a legit recaro?
                            '91 318is
                            • sandrune
                              • Sep 2014
                              • 87
                              She's all finished and running amazing!!
                              '91 318is
