Classic Daily 1975 BMW 2002 Turbo M42 Swap
  • jakeb
    • 1909
    These little guys are to mount the intercooler at the top. I am trying to make things as hidden as possible so they weld to the underside of the core support.
    Terrible picture and not pretty welds but you get the idea...
    Some welded in captive nuts at the bottom.
    Then bingo a pretty big intercooler in a 2002. (for those 02 guys...you can see there has been a little bit of cutting that took place here to fit things how we wanted)
    This car is getting AC as well so next up we need to fit a condenser.
    Sandwiched in there
    Then pulled out so you can see the upper/lower brackets for the condenser
    captive nuts to bolt the condenser in.
    We are running a disco potato on this build...so Garrett GT28RS (dual ball bearings, blah blah blah)
    Time to make it fit...
    Enough for now...more coming soon.
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
    • CorvallisBMW
      Long Schlong Longhammer
      • 13039
      Weird, the engine looks pushed really far off the the passenger side. But I suppose the crank it actually dead center.
      • jakeb
        • 1909
        Yeah the intake makes it looks off. The crank is dead in the center tho.
        • jakeb
          • 1909
          Building the turbo manifold
          Adding the wastegate connection
          All welded up for the most part
          Welded the port side..
          Sometime on the belt sander
          • jakeb
            • 1909
            It's hot and humid in the shop today so it's time to spend some time in the AC office and update build threads. It's hard to find time to do everything....gotta try and keep up on them and share. Pictures are a little out of order but will show them by job...
            Made these little mounts for the e30 m42 lower radiator bumpers.
            Welded in. Notches are to help clear the bottom of the radiator
            sits pretty nice
            upper radiator mount in progress
            I wanted to use an OEM fan from something. This happens to be from a 2010 mini cooper and should fit the bill nicely.
            made a shroud to mount it to the m42 radiator.
            A little cad work
            Some time at the band saw and you end up with these guys
            Some welding and more cad...
            and...
            Will then be powder coated!!
            • jakeb
              • 1909
              Continuing on...working on the intercooler plumbing
              Made this tool to be able to put a bead on the IC piping.
              Short one from the turbo to the IC
              I'm getting better and better an aluminum....
              From IC to Throttle Body
              Pulled back a bit
              BOV placement
              BOV flange welded on
              Air filter setup...
              This car will have AC so it needed a spot for a drier. Using a e30 drier as it is easy to replace if needed.
              Small bracket..cad first
              then metal
              welded in and drier fitted with lower AC line mocked up
              Then making other AC lines...
              had to weld to the 318 compressor fitting and add a crimp connector.
              on the car (mock up compressor)
              low side mocked up
              and welded
              Line from drier to evap in car. Fill port comes up from down low.
              Low side...this was later changed a bit.
              hold downs for everything
              All the lines mocked up
              Crimped and painted
              Inside the car
              crimper
              crimped
              installed
              • jakeb
                • 1909
                We are using an updated HVAC unit in this car and it required some sheet metal work to make it all fit....
                Cut a hole in the firewall (this is where the old fan would have popped out)
                Fitting better
                Made a mount for it
                Mount with box out
                tunnel was cut a bit too
                Remaking the tunnel to fit
                had to make a box to cover up the hole...
                Start with some cad...
                test fit
                Then made from metal
                • Dj Buttchug
                  • Jun 2010
                  • 7648
                  Nice work!
                  Turbo M42 Build Thread :Here
                  Ig:ryno_pzk
                  I like the tuna here.
                  Originally posted by lambo
                  • Chase Bays
                    • Mar 2015
                    • 36
                    This is so badass
                    www.ChaseBays.com
                    Chase Bays Instagram
                    Chase McMaster Instagram
                    • fresh_TD
                      • Aug 2013
                      • 2457
                      Subd!
                      '91 318i (Alpine) - daily
                      '88 325ix (Zinno) - drive here and there!
                      • Maikkeli
                        • 19
                        This thread is full of win. Love the effort you've put to keep the ac.
                        Keep up the good work
                        • bangn
                          • Sep 2011
                          • 760
                          I think you did a brilliant job on that manifold however its really let down by that head flange.. I would be cutting it off and doing it again.
                          Boris - 89 E30 325i
                          84- E30 323i
                          • sam_
                            • May 2014
                            • 630
                            great job on the manifold - excited to see what is to come
                            1991 325i
                            flickr
                            @sambhaskins
                            • willworkfore30s
                              • Aug 2011
                              • 1090
                              Any more progress on this?
                              • shootnjunky
                                • Aug 2014
                                • 506
                                nice build
