The sleeping E30. Bringing it back to life after almost 10 years!
  • PerryJ
    • Jun 2016
    • 26
    nice
    Nice starter for a build! I love the color combo. This will be one to watch!
    • e30austin
      • 15382
      Schwarz on Cardinal! Bitchin! Subscribed...
      • Ay Ron
        • Apr 2016
        • 17
        Been a while since I posted an update. Got a bit busy with work, got lazy with the car during the holiday season, and did a little work that I did to my wrx. Started up on the e30 again this past weekend.
        Engine and trans are back in the car after replacing the flywheel, clutch and pressure plate. Changed the timing belt and water pump as well.
        Nothing is hooked up yet in the engine bay. Lots of progress has been made for the back half of the car. Currently working on putting the rear end back together after removing almost everything.
        Dropped the gas tank just to check on the condition. My suspicions of it being no good were right - lots of rust in the tank and you could hear the sediment rolling around in the bottom of the tank. Bought a new tank and installed it.
        Pulled the fuel pump assembly out and was greeted by more rust!
        Also got the subframe back into the car after sanding off some surface rust. Gave it a bit of paint and installed some Garagistic bushings.
        The rear diff got some love too with the sand, paint and bushing action. Bushing not pictured.
        Same for the trailing arms, but I haven't put those back on yet. Hopefully this weekend coming up.
        Oh, and the WRX gained an extra gear. Almost full drivetrain swap consisting of JDM 6 speed from bugeye sti, 3.9 R180 and sti driveshaft. This swap was so worth it. Really woke the car up and now you can drive it without worrying about breaking gears!
        Next on the list is to continue piecing together the rear end and to order more parts. Need to replace the fuel pump assembly and I'm thinking about replacing the high pressure pump as well. The filler neck from the gas cap to the tank is very rusty. Hopefully I can find a solution for that without having to buy a new one at $250... considering options for this now. Few other odds and ends are on the way as well.
        2002 WRX - VF30 w/ supporting mods and now with a 6 speed!
        07/1987 325is restoration project
        • MR E30 325is
          • Dec 2008
          • 3300
          Man, 10 yrs of sitting in a wet environment. What a treat!
          Excited to see where this goes.
          Excellent stuff so far.
          My previous build (currently E30-less)
          http://www.r3vlimited.com/board/showthread.php?t=170390
          A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
          • Ay Ron
            • Apr 2016
            • 17
            Yeah, as soon as I opened up the door I knew I was in for it. The black mold behind the door panels worries me.
            Even with a deep cleaning, I'm concerned about any mold spores that might be hiding in the vents of the dash. Not sure how to approach that.
            • nrubenstein
              • 3148
              Ozone generator.
              2002 BMW M3 Alpinweiß/Black
              1999 323i GTS2 Alpinweiß
              1995 M3 Dakargelb/Black
              - S50B32/S6S420G/3.91
              1990 325is Brilliantrot/Tan
              1989 M3 Alpinweiß/Black
              • rfordo
                • Dec 2018
                • 22
                Any updates on this car? Have almost the same car beginning almost the same bringing back of life...
                • Poorhouse
                  • Nov 2016
                  • 497
                  Timely bump, I'm bringing one back to life after sitting 9 years in a field.
                  My fuel pump looked about identical to yours.
                  1991 318iC
                  1989 325i Field Rescue
                  • zwill23
                    • Jul 2015
                    • 615
                    Triple bump for a similar car with similar history, where dem updates?
                    • ArtFoodBMW
                      • Feb 2014
                      • 765
                      The answer is in the title.. The Sleeping E30
                      Also OP hasn't logged on for 1.166 years
                      • Ay Ron
                        • Apr 2016
                        • 17
                        OP here! Still working on it slowly, I've been really lazy about getting it back together, so its been sitting for the most part. I'll try to get some more pics posted here soon.
                        • Broken88
                          • Jun 2017
                          • 43
                          Where in Maryland are you?
                          • eternal24k
                            • Jul 2017
                            • 507
                            love that interior, looks like a great base for a project
                            • E30SPDFRK
                              • 5709
                              Nice project, glad that it's being cleaned up right.
                              Byron
                              Leichtbau
                              • Ay Ron
                                • Apr 2016
                                • 17
                                I'm located in the southern Maryland area, in Charles county.
