The sleeping E30. Bringing it back to life after almost 10 years!
  • Javier h
    • Sep 2007
    • 1189
    #31
    Would you replace the door or fix the rust?
    What would most body shops do?
    I ask because the same thing is happening to my car!
    • Stanley Rockafella
      • Aug 2011
      • 4062
      #32
      Cut it out and weld on some new metal.
      That's what a shop did with my my rear "is" spoiler. It was starting to rust you could hardly see anything from the outside. But once you pulled the spoiler off (factory btw, not added by me or OP) they spotted a hole they had to patch.
      Looks great now, but the trunk is also SLIGHTLY heavier, so it doesn't "POP" open like it used to :(
      Also gotta remember to disassemble that rear trunk latch/lock mechanism and clean/lube it. Seems to get VERY sticky when it's wet out.
      • Ay Ron
        • Apr 2016
        • 17
        #33
        Yup, it will need to be cut out and new metal will need to be welded on.
        That rust is now a pretty large hole. I'll need to get it taken care of once the car is back on the road. I'm a bit worried about how far it goes along the panel.
        2002 WRX - VF30 w/ supporting mods and now with a 6 speed!
        07/1987 325is restoration project
        • Ay Ron
          • Apr 2016
          • 17
          #34
          Got a few things done this weekend, getting back into it.
          Intake manifold cleaned up and reinstalled. That tube is a PITA!
          Got the fuel rail back on the manifold along with some refurbished M50 injectors. My car is an early model that has the separate plugs for each injector that was sort of a pain.
          I only realized after putting the intake manifold and rail on that I should have put the thermostat housing on first. Luckily I was able to unbolt the rail and pop a few of the injectors out to slip the thermostat housing under it.
          I have a new rubber boot hose for the throttle body that I need to install. Besides that its a few more connectors and the engine bay should start coming together.
          Also installed Rogue Engineering rear strut mounts and Condor power steering delete but don't have pictures of those.
          • 325isman
            • Dec 2010
            • 299
            #35
            This is going to be a great looking car when you finish, keep up the good work and I look forward to seeing much more.
            • Ay Ron
              • Apr 2016
              • 17
              #36
              Been a while, but OP delivers
              More posts to follow over the next few days.
              Link below is to a short clip of it running!
              Post with 0 votes and 16 views.
              • TC Baur MD
                • 151
                #37
                I'm live a little ways down the road in St. Mary's. I recently bought a white 87 is and a 86 es recently. Hoping to combine parts from both cars to make one. The es has front end damage with frame damage beyond repair. The is has rust everywhere and the guy smoked so much it put a nasty coating on most of the interior. Would love to meet up and check out your project.
                • Ay Ron
                  • Apr 2016
                  • 17
                  #38
                  I work down in St. Mary's, we could definitely meet up some time after all this craziness dies down.
                  • vasilis m3
                    • Oct 2015
                    • 54
                    #39
                    Nice work! Subscribed!
