1991 318i Project
  • CFeld
    • Jun 2016
    • 102
    1991 318i Project
    Day 1: I just bought this 1991 BMW 318i for $800 8 days ago. Perfect interior but the engine needed a little (supposedly) work. I figured I had nothing to lose.
    Day 2: The next day, with some help from a couple friends, I pulled the engine, the previous owner said I had to replace the water pump and thermostat. He also said I had to replace the oil rotor (this is bs).
    Day 3: Started engine disassembly. I quickly realize (and you may be able to see in the last picture) a lot more was wrong/ missing than the water pump and thermostat. There were no gaskets anywhere, and over the last week I have been ordering gaskets as well as other parts such as brakes and a battery.
    I will keep this thread updated as this project progresses. I would like to restore it was well as doing a couple modifications to the exterior by the time I am out of high school (I'm going into my junior year).
  • Dj Buttchug
    • Jun 2010
    • 7688
    nice start. at least the cam gears look good. maybe someone did the timing case?
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • CFeld
      • Jun 2016
      • 102
      I've got no idea. When I tore it down none of the tensioners were in. Hopefully my gaskets will all be here by the end of the next week and I will be able to put the engine back together. I have no idea if the engine even turns over or what kind of compression I have.
      • Dj Buttchug
        • Jun 2010
        • 7688
        what gaskets are missing? by the looks of it the cams are not even secured properly. Maybe the PO started to take apart the top end and then stopped?
        Ig:ryno_pzk
        • CFeld
          • Jun 2016
          • 102
          Every gasket is missing except for the intake manifold gasket and head gasket. You are also correct in that the cams were not tightened back down, which is to my benefit.
          • CFeld
            • Jun 2016
            • 102
            Update: https://www.youtube.com/watch?v=IVGyHkTDDxw
            First Start
            • 5Toes
              • 9836
              awesome project! reminds me of my e30! just mine was cheaper and a TRASHED interior that needed to go. you will grow to love the m42
              • CFeld
                • Jun 2016
                • 102
                Oh mine was cheap. I bought it for $800 and have about 600 in parts into it.
                • nk1221
                  • Feb 2015
                  • 56
                  Sweet project! I also have a '91 318i and the m42 is great. My mom actually got my car when I was in 1st grade for $300. I was given the car when I started driving and now I just graduated high school haha
                  Sent from my SCH-R970 using Tapatalk
                  • CFeld
                    • Jun 2016
                    • 102
                    My engine is leaking oil like crazy. Gotta do rear main and even though I replaced upper oil pan gasket it is leaking from there as well :(.
                    • CFeld
                      • Jun 2016
                      • 102
                      I decided to pull the engine with transmission out. I'll the engine breakdown over labor day weekend.
                      • CFeld
                        • Jun 2016
                        • 102
                        Just finish breaking down the engine. I forgot to tighten crankshaft bearing caps... 4/5 spun. No wear or anything. I'm one lucky mf.
                        • CFeld
                          • Jun 2016
                          • 102
                          Piston and Upper oil pan install. Waiting on a chain case gasket (cause usps destroyed mine in shipping).
                          • CFeld
                            • Jun 2016
                            • 102
                            First start after engine rebuild, seems good to go
                            • MR E30 325is
                              • Dec 2008
                              • 3300
                              Originally posted by CFeld
                              https://www.youtube.com/watch?v=oTTYz53uBUs
                              Nice work!
                              My previous build (currently E30-less)
                              http://www.r3vlimited.com/board/showthread.php?t=170390
                              A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
