Thought I'd start a thread on my 1986 325 that I got several years ago with 42k miles and an autotragic in her. Since then I've done several things:
Done:
Bumper tuck
Fog lights delete
Lowered on Vogtlands
4.10 VLSD
5 Speed swap (done by Bimmerbuddies when my hand was busted)
Projector headlights retrofit
Bumper fillers refresh
Map light rearview retrofit
13 Button OBC retrofit
SSK with Zhp knob
Poly trans mounts
High flow muffler
15' Basketweaves with 20mm spacers
Oil cooler retrofit
7k tach retrofit
Maybe the last item hints on my next project, an 885 head swap! But while I'm at it... how about megasquirt and wasted spark too? ;D I'm going to list what I have and what I plan to get and any suggestions are more than welcome! I would also appreciate advice on wasted spark as I'm not entirely sure how to set it up.
Have:
885 Headswap from 88 325ix (head was rebuilt, new rockers and clean valves)
Wiring harness from 91 325i vert
Whodwho Megasquirt DME V1.0 (Got for just $10!!! :o )
GM IAT sensor
APXS wideband O2 sensor
Getting:
Bosch coil pack (so I can use factory cables)
Cabling to run wasted spark?
Variable TPS (89 525i auto or E36 sensor with adapter plate?)
Intake tube with IAT bung for AFM delete
Vacuum T and 3mm hose
Maybe:
Adjustable timing gear
Crank scraper
Gasket matching ports
I also have some other things I may install
Misc:
3 gauge ashtray cluster Oil PSI, Temp, and Volts
Oil filter sandwich plate, for turbo feeding or maybe sensors?
3.73 LSD
324td crank (later with custom pistons?)
Billie shocks
Poly lollipops
Poly motor mounts
Heated sport seats (need redone in blue)
Plastic bumper swap from my other car, the black 89 325ix pictured
Full 325ix fender flare kit including door trim from 88 parts ix
Done:
Bumper tuck
Fog lights delete
4.10 VLSD
SSK with Zhp knob
Poly trans mounts
High flow muffler
Oil cooler retrofit
7k tach retrofit
Have:
GM IAT sensor
Getting:
Maybe:
Crank scraper
Misc:
3.73 LSD
Billie shocks
Poly lollipops
Poly motor mounts
