325es noob build
  • E30 Wagen
    • Jul 2005
    • 3434
    #31
    For only $600, that looks like a solid, straight car that is perfect for a project. Good work on everything, except the rocker arm shaft plugs are installed inside out.
    Originally posted by BFT_Boyle
    My Feedback
    • BFT_Boyle
      • Jul 2016
      • 199
      #32
      Thanks for catching that!!!!
      One of them got knocked out too when I was dropping the engine in (rubbed firewall) I was surprised it came out, but being inside out makes sense.
      I guess it's a good chance to crank it over with the valve cover off and verify I've got oil going through that overhead tube.
      Sent from my XT1585 using Tapatalk
      • BFT_Boyle
        • Jul 2016
        • 199
        #33
        That also explains why the plugs are rubbing on the cam gear. I thought I was missing a spacer or something.
        • E30 Wagen
          • Jul 2005
          • 3434
          #34
          You're welcome! I'd hate to see you go through all that work only to have your engine ruined if one of those fell out. I'm mid engine swap myself and in the back of my head I'm always worried about overlooking something and paying for it later.
          My Feedback
          • Ericdkollat
            • Jul 2016
            • 6
            #35
            Nice build.
            I love the torque the m20 puts out in my eta but I have to many m52s and m62s lying around and my m20 is tired at 340,000 still original. I think im swapping soon.
            Just curious, how much did it run you to resurface your head. Im about to have on done on an m52.
            • BFT_Boyle
              • Jul 2016
              • 199
              #36
              Originally posted by Ericdkollat
              Nice build.
              Thanks! I'll be building my way up.... Gotta get use to stock, then I'll chip it, then M30 swap..... Gotta milk it ;)
              I had Riebes/Napa surface it. $80 out the door. That was with me handling all thr disassembly, degreasing, and removing studs.
              • BFT_Boyle
                • Jul 2016
                • 199
                #37
                Officially blood, sweat, and cursing into this project!
                Getting exhaust hooked up from cat up.
                • BFT_Boyle
                  • Jul 2016
                  • 199
                  #38
                  Sorry, we couldn’t find that page
                  325e beautiful sound. I'll just leave this here. l
                  • BFT_Boyle
                    • Jul 2016
                    • 199
                    #39
                    Just a small update:
                    Test fired the engine last weekend. Cooling system not hooked up yet, so I only ran briefly to verify I didn't screw anything up too badly. I did discover that my tach and other gauges do not work. No SI lights either.... I'm guessing the little battery is dead.
                    My next tasks will be hooking up the new radiator, and putting a new battery in the SI board. Need to get shift linkage hooked up, as well as ordering a new guibo since mine has the consistency of a gummy bear.
                    • MrBurgundy
                      R3V Degenerate
                      • Mar 2012
                      • 5603
                      #40
                      Came here to talk shit on a newb build, but this ain't no noob build.
                      Good work!
                      • BFT_Boyle
                        • Jul 2016
                        • 199
                        #41
                        Good work!
                        Ha thanks man. It's not my first time building engines, but it is my first time with a BMW.
                        • MrBurgundy
                          R3V Degenerate
                          • Mar 2012
                          • 5603
                          #42
                          Can't wait to see how it turns out!
                          Is this your first e30 then, or just your first engine rebuild?
                          • BFT_Boyle
                            • Jul 2016
                            • 199
                            #43
                            First e30. Most of my builds have been motorcycle engines and domestic cars.
                            This one definitely has been the most extensive as far as what I've overhauled.
                            I must say I've been pleasantly surprised by how nice these M20s are to work on. You have no idea how many times my friends said, "You bought a what? Why??".
                            • BFT_Boyle
                              • Jul 2016
                              • 199
                              #44
                              Well I'm back from a long weekend at Dillons Beach and will be diving back into the engine soon. So now that it "runs" I'm working on making it run right. Smells super rich when it is running, but I'm basically running straight from the pump to the fuel rail. I'm pretty sure I've bypassed the pressure regulator, so my next step is getting all the lines put back properly. Cooling lines need connecting and I need to mount up the rest of my exhaust (even though the straight pipe sounds tits...).
                              Can I route the stock exhaust prior to installing the output shaft? I have not looked at how the routing all goes yet.
                              Guess I'll find out!
                              • e30onBBSs
                                • Dec 2014
                                • 1347
                                #45
                                Nice dude not a noob build at all more like a restoration!
                                BMW tech
                                Umass Amherst
                                05 wrx sti
