Real hard to start though. Crank for ever.... Feels like it is on 5 cylinders. I think #5 isn't firing, but it's hard to tell with the cast iron manifolds. I have not replaced the spark plug wires yet, so that could be part of the problem.
No work on the engine today, however I did pull the instrument cluster to check out the SI board batteries.
One battery showed ~1.5V while the other showed 0V. Hoping that this is the cause of my gauge issues.
Back side where the connections are soldered looked pretty crappy as well.
I also checked the odometer gear and discovered that it is stripped. Having not driving the car, I wasn't sure if the odometer worked or not. Based on the overall condition of the car, I was hoping it only had 100k on it.
More things to fix, but that's OK. All part of the fun [emoji12]
Ran the motor some more today and found a couple issues. First was that I THINK my #3 and #4 injector wires were swapped. They are the only ones not labeled. I kept trying to feel the manifolds for heat, both 3 and 4 were definitely not as hot as the others. After the swap, #3 was hot and spark plug showed ignition. #4 however was still just wet.
After checking the plug wire to #4, again, the damn connector just pulled out from the wire.
Luckily I placed an order earlier this morning for a new wire set and distributor cap. Another $200 gone like that :S but hey, at least I'll have some new "performance" wires that are blue 😁.
I think I've finally hit the $1K mark for what I have invested. Don't tell the wife 😉
Oh, final thing I found wrong was that elevation/atmospheric pressure sensor thing. I had one on the car and one from the donor. Realized the one on the car (and connected) was missing that little sliding contact finger. I installed the donor one (looks new). Not sure if I can tell a difference. Probably won't until I am running on all 6 cylinders.
Here is the old cap. Can't believe the thing actually fired up [emoji38] Too late to try and start with the new if ignition components (still mostly straight piped) tonight. Tomorrow will be a good day. It's kinda like Christmas Eve though. I won't be able to sleep!
I didn't read all your pages. .but the #1 cause for M20s running rich, is the temp sensor that screws in your thermostat housing.
Hmmm. It fails rich then? If I disconnect does it fail lean? Guess I could look up the ohm spec. Checking timing now. I used the reference points in crank and cam gear, but have not checked since I put the pulley on
Check it according to the values found in the Bentley when hot and cold. Also check the same value at the ECU end of the harness to make sure that there is no break in the harness. This sensor is the main input for thr ECU to determine the correct fuel mixture.
Another thing to check is the throttle position switch under the throttle body.
'91 318i (Alpine) - daily
'88 325ix (Zinno) - drive here and there!
