My '89 325ix
  • ThatM20Guy
    • Aug 2014
    • 600
    Originally posted by driftxsequence
    What was your issue with the carrier not fitting? Mine stock shifter fit, I had to simply grind down the edges of the bushing in the shift rod. I think because your assembly is resting low, it is showing an interference - if you hold it up parallel or higher it will be fine! See my build thread for the few pictures i took..haha
    Mine doesn't clear the bezel with the stock shifter. Even in the rough mounting position it is no where close to fitting. Z3 1.9 arm was only $64 so I'm not to mad about having to order one
    89' 325ix Diamantschwarz/Black rattle can...
    Insta: r_moose_w
    Originally posted by flyboyx
    I imagine her smelling like spoiled milk and having a half inch crust of doodoo circumnavigating her butthole.
    • stonea
      • 2892
      Originally posted by ThatM20Guy
      80a motor mounts and trans case mount
      Front subframe reinforcement plates
      I'm sure you've either figured this out or about to, but the ix doesn't have trans mounts, the motor mounts are ix specific, and it has a different front subframe than RWD e30s so those reinforcements aren't going to work. Good thread though! Makes me want to get back to work on my ix.
      My Garage
      Feedback
      Instagram: Stone.Hopkins
      • ThatM20Guy
        • Aug 2014
        • 600
        Thanks! The ix can be a bit of a pain but it's totally worth it :D
        As to your comments, meant to say transfer case. I had garagistic make me a set of 80A motor mounts and the t-case mount so I should be set there. Didn't think about the motor mounts being completely different when I bought em...oops
        So now I have is trans mounts from a flub up from garagistic (Sent me is instead of ix) as well as is reinforcement plates. hmmmm. Seems I need to get an is to use all of these parts
        Insta: r_moose_w
        • driftxsequence
          • Apr 2015
          • 203
          I still dont follow you. I used the stock shifter with garagistic DSSR and delrin front/rear carrier bushings.
          325IX Build Thread
          RX7 Build Thread
          • ThatM20Guy
            • Aug 2014
            • 600
            Idk. Best I can explain it. But it definitely doesn't fit that is for sure.
            Insta: r_moose_w
            • ThatM20Guy
              • Aug 2014
              • 600
              Got the sideskirts mostly fixed. The PO put some weird ass black silicone/adhesive shit to try and glue on the sideskirt and it totally didn't work. The skirt pulled away from the side and left an ugly hard residue. Got some sideskirt clips so I was able to get it back to looking mostly good. Still need to sand off the rest of the dried crap.
              Installed the DSSR the other day and got the trans up an in. Originally thought the DSSR would clear the t-case and the flex disc. Took if for a drive yesterday and it wasn't happy. Almost impossible to get into R-1-2-5 due to the corners of the DSSR hitting the tcase. You can shift in 3rd and 4th but you can definitely feel rubbing. Whenever the driveshaft is spinning there is a not quite clicking noise but definitely sounds like it is rubbing on the guibo. Transfer case will have to come out this weekend just so I can file down 1/8 inch of metal. Not to happy about that.
              On a side note, I am still waiting for the tcase mount that I ordered from Garagistic late December. They screwed up the order the first time and I had to wait 5 weeks to get it, and now they said they shipped it out on February 14th and still no tracking number or any updates on the shipping.
              Will throw some pics up when I get home
              Insta: r_moose_w
              • litu
                • 849
                sub, cool project
                https://www.facebook.com/Cry_77_IX-110483784967661
                https://www.instagram.com/cry_77_ix/
                • ThatM20Guy
                  • Aug 2014
                  • 600
                  Originally posted by litu
                  sub, cool project
                  Thanks man!
                  I got big plans for this project...did somebody say 2.8 high comp itb build ;D
                  Insta: r_moose_w
                  • litu
                    • 849
                    Wow that sound cool...
                    • jeenyus
                      • Aug 2011
                      • 2064
                      great progress! We ix members gotta stick together. Let me know if you ever have any questions and vice versa.
                      • ThatM20Guy
                        • Aug 2014
                        • 600
                        Thanks! Slowly but surely making headway. Still chasing idle problems which are my main enemy as of now.
                        And we sure do!!! Not many around now a days so it's always cool to see another one around. :D
                        Insta: r_moose_w
                        • jeenyus
                          • Aug 2011
                          • 2064
                          I've gone through the list for idle. I think I've replaced almost everything at this point. I was having an issue with my car dying after it starts for so long. I've replaced everything except the CPS which was probably the issue all along. I'd say for idle though, it could be anything. Probably vacuum
                          • ThatM20Guy
                            • Aug 2014
                            • 600
                            I only have 2 vacuum leaks left which are the 2 metal elbows coming off the throttle body. Just have to JB weld those in place. After that if my idle is still wonky basically the only thing left that would be wrong is the coolant temp sensor which I am pretty sure is my problem. It idles fine when warm, just on cold starts it wants to die.
                            Insta: r_moose_w
                            • jeenyus
                              • Aug 2011
                              • 2064
                              I'd think about the crank position sensor. I regret not replacing mine earlier.
                              • ThatM20Guy
                                • Aug 2014
                                • 600
                                I'll look into it. A new coolant temp is only $15 so I'm going to try that before I get a $60 cps. If the crank sensor was bad wouldn't it affect more than just the cold start idle? I feel like it would affect the whole rev range, but I am pretty new to e30's so I could be wrong
                                Insta: r_moose_w
