My project 84 318i
This topic is closed.
  • kronus
    • Apr 2008
    • 13032
    #301
    It's an OEM Euro Sport lip for the early models. I don't think mine was on there from the factory.
    cars beep boop
    • Jean
      • 18228
      #302
      Here is the euro fog light covers, they need some kind of clips to hold them in place though....
      • Jean
        • 18228
        #303
        And here is the look for now until I get it lowered, center caps are waiting for new emblems, and then m-tech valances.
        Temporarily on 89 325i springs from my white e30.
        • Danny
          • 14216
          #304
          Holy Jesus that's high.
          Lookin good though.
          • Jean
            • 18228
            #305
            Pulling the dash out for the last time to put this in. Finally got the right heater/blower box from another 84 318i. This thing is complete, and will get cleaned up with new gaskets :)
            Got an a/c compressor, and a condensor as well. Came out of low mileage automatic car.
            Going to order dryer, expansion valve, couple new lines and o-rings.
            Also, picked up a radiator to replace my jb-welded radiator, with a fan shroud. Got a clutch fan thanks to r3v member, just need to get a fan blade.
            • BrewCity11
              • Mar 2008
              • 2335
              #306
              My first time checking out your build. Good work, Jean.
              I'll be watching this one......
              turk@gutenparts.com
              • ZM Blue Devil
                • Dec 2006
                • 13836
                #307
                this is awesome. Nice to see a project done right. I'm not sure but I think there are more new parts on this car then old at this point. She is a lucky girl.
                Levent
                %20levent@gutenparts.com
                Ladies:
                • E30nate
                  • Oct 2007
                  • 1050
                  #308
                  lookin good jean. its a good thing some cool dude on here told you about those bumpers;)
                  • Jean
                    • 18228
                    #309
                    Yep, it was perfect timing too! ty
                    Replaced the radiator last night and installed the fan shroud, need to order a fan blade and install the clutch fan. Runs at 1/2 temp now with electrical fan on 1/2 speed.
                    • Jean
                      • 18228
                      #310
                      Removed the dash, installed the correct blower/ac/heater box with new gaskets. Replaced the dash with another cleaner dash, along with the a-pillar cover. Now, for some reason the motor actuators on the blower/ac box constantly run and won't turn off... I tried another set of actuators and they are doing the same thing...so, I am wondering if it's because I don't have an A/C Button plugged in? For now I unplugged the actuators.
                      I now have a working fan lol. Evaporator is also installed, now need to install a/c lines and compressor and condensor.
                      Pictures:
                      Step one, remove the steering wheel
                      Step two, remove the consoles
                      Step three, remove driver side knee pad and cluster
                      Step four, remove the hvac controls and clock
                      Step five, drop the glove box
                      Step six, remove a-pillar covers
                      Step seven, remove dash
                      Step eight, enjoy the view
                      Step nine, grab the corect a/c blower box with all the controls and wiring
                      Step ten, get the new gaskets to replace the old ones
                      Step eleven, install new gaskets
                      Step twelve, install the blower, ac box in the car
                      Step thirteen, swap the vin number on the dash to match the car
                      Step fifteen, connect everything up
                      Step sixteen, install hvac panel and switches
                      Step seventeen, install consoles and trim
                      Install steering wheel, go for a drive, make sure it's centered.
                      Next, a/c lines and replacing overhead panel.
                      • Jean
                        • 18228
                        #311
                        Replaced the overhead headliner panel with a mint one, so no sagging vinyl anywhere and replaced the early side mirrors with body painted mirrors. Nothing huge, but cleans it up a little bit.
                        Have not installed the compressor and remaining a/c lines yet, so still need to do that.
                        • ZM Blue Devil
                          • Dec 2006
                          • 13836
                          #312
                          coming along nicely.
                          Levent
                          Ladies:
                          • 2002maniac
                            • 4260
                            #313
                            how did you swap the vin tags? arent they riveted on?
                            • alpinaclone
                              • 820
                              #314
                              You just drill out the old rivets and shoot new ones.
                              Matt
                              • Jean
                                • 18228
                                #315
                                Didn't even have to drill them out, used a sharp tool to push the pin in the rivet out and then re-install.
