86 eta 5.0 swap...
  • Elysian
    • 674
    #196
    Work has been crazy, hence no progress in a while. I did get some thinner MIG wire and new tips, but probably won't have time to finish the new oil pan till next weekend.
    • Elysian
      • 674
      #197
      Ordered the JagsThatRun Heavy-duty driveshaft flange for BMW V8 engine swaps, as well as a Spicer yoke for the transmission end. Will have a driveshaft built that uses 1310 u-joints, going to try to get it in queue at a local shop this week.
      • zwill23
        • Jul 2015
        • 615
        #198
        Haven't noticed your build before! Congrats on the first start.
        Cool to see a V8 E30 project in the area :up:
        • Elysian
          • 674
          #199
          Hoping to have it at least moving before long. My HOA probably gets complaints all the time about it, but so far they haven't said anything.
          • Elysian
            • 674
            #200
            Got some work in today. First thing I did was put an endoscope down a spark plug hole to make sure there was no contact between the valves and the pistons. So far so good.
            Then I started working on the fan and radiator. The fan is from a Ford Fusion (thanks Laminar on BF.c for the idea).
            Have about an inch of clearance.
            So started working on the radiator. Welded in some metal that I could use to actually mount the radiator. Still a work in progress, but a good start.
            And the radiator sitting in its new home.
            I had to cut a hole in the top of the core support for the fill hole, but that's not a big deal. I also had to remove the hood latch, I'll patch in some new metal next time. Need to go grab some self etching primer, don't want this stuff to rust.
            • Elysian
              • 674
              #201
              I'm not a great welder, but I'm pretty happy with how this came out.
              Have a lot more reinforcements to weld in, but this is a decent start.
              • lukeADE335i
                • Apr 2013
                • 1389
                #202
                I've thought about modding the radiator support in a similar way to accommodate a clutch fan on my M30 so that I can run AC... how do you intend to keep the hood shut? This was the sticking point for me thus far.
                My e30: OEM+ with M30B35
                • Elysian
                  • 674
                  #203
                  I have those Aerocatch hood pins, love the way they look, and got the locking type.
                  I can find the model of the radiator if you'd like, it's one from Summit.
                  • Elysian
                    • 674
                    #204
                    I'm no welder, part deux...
                    Welded in the camber/toe adjustment setup for the rear subframe, then rust converted and primed.
                    • Elysian
                      • 674
                      #205
                      Productive weekend. I finished the replacement oil pan and primed it, need to do a top coat with engine enamel. It's ugly, but it doesn't leak, I left it sitting with water in it for over an hour.
                      I also started taking the trailing arms apart, got one fully disassembled, started to strip it, and welded on the reinforcements. I welded the plate reinforcement top and bottom... My welds aren't too awesome, somehow I can color in the lines but can't weld a straight bead to save my life. I tried going over the first bead again, and it just wound up more crooked, and got some porosity...
                      Oh well. I still have another one to do, maybe it'll come out better. Need to prime and paint this one, but have one more small plate to do. A buddy gave me some tips to improve my welding, so I'll practice those before I tackle the other trailing arm.
                      • Elysian
                        • 674
                        #206
                        I've got the entire week of Christmas off, so planning on getting a ton of work done.
                        • Elysian
                          • 674
                          #207
                          Was busy most of the day, but went out and welded in another small reinforcement on the rear trailing arm. I'm happier with this one.
                          • Elysian
                            • 674
                            #208
                            Got the other trailing arm stripped down, now need to clean it up and prep it for welding. Will probably do that tomorrow.
                            • Elysian
                              • 674
                              #209
                              Finished welding the trailing arm and got everything primed with etching primer and painted black.
                              Still have a bunch of parts I need:
                              Wheel bearings
                              E46 rear brake caliper adapter
                              E46 rear brake calipers
                              E46 rear brake pads
                              Z4 rear rotors
                              All E-brake parts
                              Brake lines
                              Brake dust shields, both sides (were very rusted out, the E-brake parts just broke right off the shields)
                              So won't have the rear end together any time soon. I think I'm going to shift my focus to the front subframe now, need to pull the one out of my 86...
                              • Elysian
                                • 674
                                #210
                                Pulled the front subframe from my spare E30 today, managed to do it without even getting under the car. A good thing, as it's been raining and was really muddy under there.
                                Going to be attempting a tubular front subframe for this, may even try to run a rear sump oil pan on the V8...
