86 eta 5.0 swap...
  • Elysian
    • 674
    #151
    Originally posted by varg
    Bummer. Does it hit the head or just the valve cover?
    Valve cover, would hit the valves underneath too, even with stock valves. Probably would just touch the head as well, couldn't get very far with it in place, thankfully only secured it with 2 nuts.
    • Elysian
      • 674
      #152
      Is there any benefit to making the driveshaft 2 piece? The E30V8 instructions say a 1 piece shaft can't be removed/installed easily, I'm wondering if it's worth it/possible to have the driveshaft shop keep the stock split location.
      • Elysian
        • 674
        #153
        Meanwhile, got this on the way, thanks to Mykk540i/6.
        • Elysian
          • 674
          #154
          Hit the junkyard, grabbed a starter and a set of GM LS truck coils.
          • Elysian
            • 674
            #155
            Upper intake is painted.
            • varg
              Florida Turbo Man
              • May 2014
              • 3425
              #156
              Good to know. Looks like I'll be doing further research on manual brakes.
              IG @turbovarg
              '91 318is, M20 turbo
              • Elysian
                • 674
                #157
                What about hydraulic?
                • Elysian
                  • 674
                  #158
                  Had time for real minor stuff yesterday. Grabbed a pair of 7/16-14 set screws, a 7/16-14 tap, and plugged the two vacuum lines that interfere with my valve covers. Didn't need them anyways, but used red Loctite, just in case I ever did need them again.
                  Also picked up a PCV grommet. Need to finish up the wiring on top of the motor and start putting the intake manifold on. Not sure which direction I'll be bolting the manifold on, any input is welcome.
                  • Elysian
                    • 674
                    #159
                    Added AT LEAST 40hp today.
                    • Mykk540i/6
                      • Oct 2014
                      • 175
                      #160
                      Great seeing it come together! Keep up the good work
                      • Elysian
                        • 674
                        #161
                        Fuel rail came in, started putting it together to see if the intake fits. It doesn't, but it won't be hard to fit, the fuel rail is just barely touching the bottom of the manifold in one spot. Plenty of meat to clearance there.
                        • Elysian
                          • 674
                          #162
                          • Elysian
                            • 674
                            #163
                            Got most of the wiring done. Need to wire up the TPS and idle control, drill/tap for the idle air temp sender, and mount the alternator to include that wiring. Coming along nicely.
                            • varg
                              Florida Turbo Man
                              • May 2014
                              • 3425
                              #164
                              Expensive! For the money I'd rather get an aftermarket pedal box with 3 separate masters. Current plan is a smaller bore master cylinder and altering the pedal ratio.
                              IG @turbovarg
                              • Elysian
                                • 674
                                #165
                                What's expensive about it? Ford used hydraulic brake boosters in the Mustang, can find the setup in just about any junkyard. GM also used them quite often. You'd probably still have to move it up or over to clear the valve covers, but doesn't seem too expensive to me.
