*!Build of the year candidate!* Strange PNW Build: E30+Volvo
  • adam.nonis
    • Apr 2017
    • 755
    #46
    What does this do? Is there a way to bypass it?
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      #47
      Over flow tank for fuel system
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • adam.nonis
        • Apr 2017
        • 755
        #48
        Overflow as in return from rail? Does there need to be a storage tank there? Can I just "Y" all the lines together?
        • UgkNW*
          • Oct 2013
          • 259
          #49
          Quick question can I use a water pump pulley (plastic) from a 95 M50tu on a 97 s52
          • adam.nonis
            • Apr 2017
            • 755
            #50
            I have no clue.
            • adam.nonis
              • Apr 2017
              • 755
              #51
              • adam.nonis
                • Apr 2017
                • 755
                #52
                Strange PNW Build
                Just checking.
                • bmwm42
                  • 6300
                  #53
                  Wicked
                  Originally posted by bmwm42
                  PNW vulture pm me for parts
                  Strategic nw e30 command
                  • UgkNW*
                    • Oct 2013
                    • 259
                    #54
                    anyone
                    • Matt-B
                      The Waffler
                      • 3856
                      #55
                      yes
                      i have the 8% increase under drive for m50 pulley ( i bought 2 from ECS )
                      on my s52
                      • UgkNW*
                        • Oct 2013
                        • 259
                        #56
                        Yo Matt thanks.
                        • adam.nonis
                          • Apr 2017
                          • 755
                          #57
                          Boring as sh!t to watch, but feel free to pop in once in a while.
                          • adam.nonis
                            • Apr 2017
                            • 755
                            #58
                            Day one of the week off in the books.
                            Tomorrow should be a little better. I don't need to run around picking stuff up. It's going to be just fabrication stuff. Plus drilling out a bunch of spot welds. Today I got the gantry set up, the body lift rigging fairly level, the fuel overflow tank relocated and one half of the Amazon inner rocker drilled out. I made the kids clean the inside of the E30 out (it's like pulling teeth to get them to help). Tomorrow I'll drill out the other rocker first, then just straight to lifting the body and test fitting.
                            • adam.nonis
                              • Apr 2017
                              • 755
                              #59
                              Live Stream Day 2
                              HQ Day 2
                              • adam.nonis
                                • Apr 2017
                                • 755
                                #60
                                Getting closer. It's a process of lower, mark, raise, trim, lower, mark, raise, trim until I get it where I want it. Then it'll be raise, grind, weld prime, lower and weld.
