Doesn’t seem like a lot to me for four days worth of work. Today was just priming the driver’s side and clean/organize the shop. I still need to emboss the passenger fender, bodywork the roof, hood and grille shell. Blow it apart to spray the jambs and reassemble for block/paint the outside. Ugh. Not enough hours in the day.
*!Build of the year candidate!* Strange PNW Build: E30+Volvo
Originally posted by oekundar View PostAdam- what type of primer are you using on the car?
Unfortunately it’s a generic primer from WESCO Autobody. I can’t afford something high end. What I do like about it is by deleting/or adding the reducer in the mix, it can be a high-build primer, a surfacing primer or a wet-on-wet sealer. I will be using a nice PPG sealer when I paint, so I think I’ll be ok. I’ll try and get a pic of the primer can later. I need to buy more.
Originally posted by LateFan View Posthmm...could you make those blink with the signals? (sorry to suggest making this any more complicated!)
That’s the plan!!
Sanded the roof with 80g to prep for bodywork (no pictures), embossed the other fender (no pictures) and sanded out some lacquer checking in the old old paint (no pictures) this AM before going to work. Then I started on the new hood hinge system. Might be sad news for some people, but I’m just designing a front tilt style hinge system. The other style was cool, but needed lots more engineering and was putting weird stresses on the hood itself. I also had a lot of figurin to do for the rear latches. Anyway, hinge work.
Template to figure clearances.
Rolling some square tube for the crossbar. I tacked then together so the radius would match.
Missed some in between pics. Try to get some more tomorrow. Short videos to come.
Nothing new to post. Well, not much. Got the most notable dents/dings worked out of the roof and loaded it up with a couple heavy coats of high build primer so I can guide coat it and knock it back. I know it’s wavy in some spots, but I’m pretty sure the high build will eat it up.
Hoping to possibly maybe hopefully cut the first parts in this weekend. We’ll see.
I just gotta give a huge thank you to Vogue Autowerks in Kirkland, WA for letting me work on the Amazon there. I know most of you guys aren’t local to Seattle, but if you are and have a need for the services they offer, please feel good about supporting them. There’s no way I could get all this done in my driveway with the weather the way it’s been (and is supposed to be). I kind of feel bad invading their shop a bit. Mostly because everything I’m doing is dusty and messy. We all need help from others and they’ve really come through for me.
If you want to follow them,
IG: @vogueautowerks
FB: @vogueautowerks
