89' vert resto-mod
  • Mook613
    • Apr 2016
    • 232
    89' vert resto-mod
    My journey began as a desire for a cheap car that would easy to work on and fun to drive (ie. a manual transmission). At first I was looking at Miatas and early-00s Subaru WRXs. Then I stumbled across the massive cult following of the E30.
    Many hours spent on Kijiji lead me to see a lot of cars with rust, which was a big no-no in my search. Ultimately finding a 'rust-free' car in Toronto is pretty challenging unless you buy brand new. Alas, I found this 89' vert. It had only 172,000km with a fresh head (courtesy of a previous owner not changing the TB), and from what I could see no rust.
    The person that did the work on the head certainly has experience with the cars and gave me some photos of his work (clearly took pride in it).
    At first, I just wanted to do some paint correction, clean it all up and drive it. I quickly began ordering parts and it all spiraled a bit out of control.
    Here is the car when I picked it up in March of 2016.
    It looks OK, but had a mismatched fender (wrong red), a bad muffler and the paint was oxidized. Also was sitting on very low springs and needed some love. It did have Bilstein shocks and struts.
    After having the muffler replaced with some custom stainless steel pipes I had the car delivered to Bavarian Motorsport for Steve (for those who know him) to give the car a once over and list everything 'wrong' with it. He gave the car the safety check that I needed for licensing and then I let him do a bit of work:
    - Brake lines (including the ones above the rear subframe)
    - Replaced fuel tank, fuel lines, and filter
    - New engine rear main seal
    - New trans in and out seals
    - New shifter bushings
    - Fresh oil and brake fluid
    - Checked to make sure that engine was in good health and that it would pass emissions (which it did 1-week later with near perfect results).
    His recommendations were to replace my brakes and subframe bushings ASAP.
    After getting the car back from Steve I did a valve adjustment and replaced the transmission and diff fluids.
    My first big parts order included:
    - H&R springs (to replace the FK springs that were too low for me)
    - Revshift polyurethane rear bushing kit
    - Zimmerman brake rotors
    - Pagid brake pads
    - Front strut mounts
    - Valve cover gasket
    - Parking brake cables
    - Lots of other odds and ends
    I was supposed to have a 'budget'... that concept didn't last long.
    This was my first car that I was going to do such extensive work on, and at this point I was getting anxious, but extremely excited.
    I tackled the brakes one morning and then the front springs and mounts were replaced the next. Was making very quick progress...
    Then I decided that I was going to do the rear bushings. Armed with the knowledge of the online guides I figured it wouldn't be too difficult.
    I picked a random night and started working on dropping the rear end, all of the work being done in the bowels of my apartment's underground garage.
    It was going pretty smoothly, and I was able to use the lag bolt and threaded rod trick to getting the bushings to drop without leaving the sleeve embedded in the car.
    BUT, it took me a loooong time as I was only working an hour here and there after work in the evenings.
    I brought the subframe, trailing arms and the diff up to my in-laws house where I could brush off the rust and apply some new paint. Having them painted in their garage was where I planned to leave this project before going on vacation for 10-days. I received a call at 3pm the day before I was supposed to get on a 6:30am flight. My landlord was freaking out about the car (which was sitting with its driveshaft and exhaust next to it for almost 3 weeks). He said that the building owner was calling the fire-department to have my car removed due to safety concerns.
    Here is what my parts looked like when he called:
    I've never worked so hard, but I started at 5pm and by about 2:30am I had the subframe back in and was able to lower the car onto its wheels again.
    It looked good enough, despite not having working brakes or parking brake. Showered, packed my bag, and woke my wife up to get into the Uber and off to the airport (slept well on that flight).
    Crisis averted!
    Next step was to compound and polish the paint. Went well but there were some dents that would need to be fixed. I did do a lot of PDR on the trunk.
    Replaced the ignition system except for the wires (they looked new already). Meant ordering new plugs, rotor, cap, etc.
    Also put in rebuilt M50 injectors from MEPEH.
    Before the car was put away for the winter I had the A/C system overhauled for R124. New compressor, condenser, aux fan and relays. Blows nice and cold.
    Wasn't a lot of flow coming from the vents... we quickly found out why.
    I picked up a hardtop for the colder months so that I could drive when the roads were dry. My wife helped me strip out the old headliner and put in some nice perforated black material (no photos).
    After the winter I put in a refurbished AFM from Gregory and rebuilt my throttle body with a working TPS.
    Had a smoke test done and found the valve cover hose to be bad. Once replaced my idle was dead steady at 700rpm, but the car still shook a bit while idling. Solved this more recently with the HD mounting kit from Garagistic. Now it's nice and smooth.
    I stripped the anodizing off of one bumper with oven cleaner and then sanded/polished it to a mirror shine.
    Coolant gauge was only going to the first white mark, so put in a new thermostat, new fan clutch and put in some nice red silicone hoses.
    Bled the system and now it quickly goes to half-way and stays there.
    It took some time, but I started to fix up the dents and dings in the paint to prepare it for a proper paint job.
    Used 2k epoxy primer to ensure nothing would rust.
    Then the car was sanded back, coated with a sealer primer, and a few coats of base followed by a few coats of PPG ceramic clear. While the trim was off I wrapped all the chrome with black-chrome vinyl wrap. Mutes it all nicely.
    Was told to not polish or coat the paint for 90 days so that it could off-gas.
    So I started to tackle a bunch of smaller projects.
    Rebuilt the brake calipers and gave them a coating of paint. Installed some Garagistic SS brake lines too.
    Red calipers look great with the gun-metal wheels (Enkei Compe in 16x7, w/ 205/50R16 Firestone Indy 500 tires)
    OBC light went out, so soldered in some LEDs.
    I bought some Leatherique, Leather World Tech's kit, and a nice Badger airbrush. Seats were disassembled and then sat soaking in the Leatherique oil for a few days before being resprayed with new dyes.
    Picked up an E46 ZHP rack locally and installed it with new E36 tie-rods only a few weeks ago...
    While the car was up on the lift the car got a new oil pan gasket to stop some leaks.
    So far the rack has been the best money I have spent on this build!!
    Disassembled my cluster to adjust the fuel gauge and speedometer. Resoldered the resistor for the brake-pad wear indicator while I was in there.
    After waiting the 90-days I finally had a chance to polish and seal the fresh paint. I may go back and wet-sand/compound some parts, but for now I just polished and put on some Klasse glaze/sealant.
    There are still a few things to do:
    1) Flock the dashboard
    2) Cover some of the trim inside with micro-suede to match the flocking
    3) Install my Renown steering wheel (waiting for my Momo hub to come in - apparently it's sitting at customs)
    4) Figure out why one of my mirrors isn't working (the wiring into it comes out with the same polarity rather than alternating).
    5) Find a nice set of carpets
    6) Long term I'll need to replace the soft-top.
    7) Find a type 4-2 coding plug for the OBC
    I still can't believe how much has been accomplished since last year. This car gets A LOT of attention and is great fun to drive.
    There are so many parts that I have put in to keep this car in top-shape. Things such as fuel senders, missing trim pieces, seals, etc. One day I will need to pull out all of the receipts to figure it all out, but scared to think of just how much this has all cost me.
    Sorry for taking so long to post the build progress, but I didn't want to show the car until it looked presentable.
  • cspec
    • Apr 2017
    • 182
    Could you elaborate on how you did the hard top headliner and share some pics? Would be very interested!
    • Mook613
      • Apr 2016
      • 232
      I didn't take photos of the process (regrettably), but it was pretty straight forward.
      Take off the handles by removing the caps on the ends and then unscrewing them.
      Then just start pulling out the old headliner. I brushed away any of the residual glue and fluff that was left behind.
      Ideally you'd cut pieces for the rear sections and then stitch them together as the original material was prepared, but I wasn't going to do that.
      Rather I laid down the material and cut to be just a bit bigger in each direction.
      Used 3M 77 spray adhesive and sprayed the the middle section (about 1 foot). Spray both the hardtop and the new material. Wait a few minutes for it to tack and then press it down gently.
      I then did 12-inches at a time moving forward.
      Cut the excess, but leave about an inch to be tucked under the seals.
      Used a credit card to tuck the material under the rubber seals and into the recess at the front edge.
      The rear parts are tricky but I had no trouble with the flex in the materials to be glued down to the sides.
      Ideally you'd remove the rear glass (I think) and then wrap the material around the wooden parts just below the glass. But I just glued it down and then cut the excess material.
      Is it perfect? No... will anybody notice? no.
      Looks very good (100x better than before) and for the few hours it took I'm happy.
      • Mook613
        • Apr 2016
        • 232
        Car had a no-start issue on the weekend. After some diagnostics, found that the battery and starter were okay and that it was likely the engine ground strap from the oil pan to the body. As the car was in my building's underground (and based on my history of working down there) i took advantage of my roadside coverage and had it towed.
        I already had the car planned to go to a shop for a compression and leak-down test, so wasn't a big deal and didn't cost anything other than a little time.
        Results from tests-
        Compression:
        #1 = 75 - 155
        #2 = 75 - 170
        #3 = 75 - 175
        #4 = 75 - 175
        #5 = 75 - 175
        #6 = 75 - 180
        Leak-down:
        #1 = 50-47
        #2 = 50-50
        #3 = 50-49
        #4 = 50-50
        #5 = 50-49
        #6 = 50-49
        So I do have a little blow-by coming from #1 but still very healthy overall.
        • Mook613
          • Apr 2016
          • 232
          Also, some things I forgot about but were done at some point:
          1) End-links replaced when I did the subframe
          2) Rebuilt the oil filter housing with o-rings, gaskets, thermostat, etc.
          3) Replaced the oil cooler and lines (mine was dented and lines were seeping)
          There's more that I am likely forgetting about, but will keep the list going as I remember.
          • N2MYE30
            • Oct 2007
            • 5536
            Wow, nice work so far! :up:
            COTM
            • sonomabimmers
              • Dec 2015
              • 802
              Loving this thread. nothing better than quality work
              i love bmws
              • TimeMachinE30
                • Jun 2014
                • 3749
                Cool stuff!
                What are your thoughts on leatherique?
                ACS S3 Build / Dinan 5 E34
                • Mook613
                  • Apr 2016
                  • 232
                  Originally posted by TimeMachinE30
                  Cool stuff!
                  It is an amazing product. I cleaned the leather by scrubbing with a pad and all-purpose cleaner and thought that it was clean. Then after letting the oil sit for a few days I used the cleaner and then saw a whole bunch more gunk come off the leather.
                  It also softens the leather a lot!
                  • parkerbink
                    • Jun 2004
                    • 10138
                    Very nice, enjoy!
                    • Mook613
                      • Apr 2016
                      • 232
                      Finally received my Momo hub and installed the Renown steering wheel that has been sitting on my dining room table for a few months:
                      Some install notes:
                      1) If getting a Renown wheel then get the Momo hub as it makes installing very easy (it grounds the horn button without a ground wire being added).
                      2) You don't need the extra ring with the wheel when using this combination
                      3) Make sure to place the wheel on the hub so that the plastic piece on the rear side of the hub is in the same orientation as the stock wheel. If you don't do this then your turn signals will not release properly.
                      The combination of an E46 steering rack and a 350mm steering wheel is something that takes getting used to. The steering is very direct with 0 'sneeze space'.
                      I may swap the wheel at some point for something with a thicker grip at the 2-10 positions as this is a daily driver, but will see.
