DD 318is comfort Build & Track prep 325is
I have never understood why people swap out 21lb injectors for 19lb injectors for performance gain. I guess if you recal to match the lower flow rate of the injectors the idle is probably better with the better atomisation. Never understood why people don't get injectors with newer technology that flow as much as stock or greater.Get some 4 pintle 19# injectors and a sssquid chip for it. The transformation is great. You will thank me and so will the m42. Also clean up the mess under the intake if you haven’t. Its really simple. If its likely had a head job then you timing chain and guides are likely new so no worries on those.
Just food for thought!-Nick
M42 on VEMSComment
Hmm maybe i got the wrong info but if i recall i thought the m42 flowed 18ishI have never understood why people swap out 21lb injectors for 19lb injectors for performance gain. I guess if you recal to match the lower flow rate of the injectors the idle is probably better with the better atomisation. Never understood why people don't get injectors with newer technology that flow as much as stock or greater.
Just food for thought!Comment
In, sick car. Want to get compomotive THs for my 318, but they discontinued the 16" version. What tire size are you running on the 17s?M119 M42 M62 S52 S62Comment
Stock injectors are 19 pound single pintle.Comment
Ah, you got me excited there. I thought you said Mtech 1 (370mm). I would have gladly taken that off your hands and made your decision easier :)
Dash is blah original dash and its cracked I just hide it until I find a decent dash locally. Right now the big decision at hand for me is a 370mm Mtech 2 wheel or renown with white stitching I feel like this would complement better but I like obtaining more rare sought after parts so idk.-ALaSComment
Im actually waiting on a quote from personal on a lesmo wheel. If its to outrageous im going to be picking up a mtech1 370 if a member on here still has it.Comment
Show and no Go 318is DD comfort Build.
Good choices. Since you have an air bag car make sure you space out the wheel with the spacers or washers depending how much it needs spaced. You may also need to pull the white tab and spring out of the column that automatically turn your blinker off as on some wheels it will catch and lock the wheel up for a split second. On my 318 i had to use washers and pull that tab out. Not that big of a deal to me but may be to some.Comment
Stunning build. I absolutely love those seats! They're gorgeous and look right at home.1988 325 Lachs Sedan SOLD
1989 325i Bronzit Beige 2 Door
SOLD
2018 Volkswagen Alltrack SE DSG
Past:1988 325iS Lachs 5 SpeedComment
Got my an email back and apparently i cant pick up the lesmo i may wait out for a nardi blackline one of my favorites outside of the mtechnicsGood choices. Since you have an air bag car make sure you space out the wheel with the spacers or washers depending how much it needs spaced. You may also need to pull the white tab and spring out of the column that automatically turn your blinker off as on some wheels it will catch and lock the wheel up for a split second. On my 318 i had to use washers and pull that tab out. Not that big of a deal to me but may be to some.
Doesnt that very hub to hub?Comment
