Cooperman's 91' 318is restomod+ cammed M90 swap
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    sub'd for big 6 fun
    • cooperman
      • Nov 2009
      • 219
      Hey @captain awesome ! Glad you chimed in. I will let you know if I need help. Likely will when the engine goes in.
      M90= Bore 93.36 mm x 84 mm stroke
      M30= 92mm X 86 mm
      M90 is a stump puller. It will be on the dyno for sure. I want to know what it makes.
      • cooperman
        • Nov 2009
        • 219
        Pressed out the rear bearings then prepped and painted a bunch of stuff.
        DSC01882 by Micah Cooper, on Flickr
        DSC01884 by Micah Cooper, on Flickr
        The other whips.
        2000 528i Msport manual
        1997 Landcruiser
        DSC01885 by Micah Cooper, on Flickr
        • 2mAn
          Señior Mod
          • 21014
          M30= 92mm X 86 mm
          yummy, bigger bore, shorter stroke, and same effective displacement. my kind of motor. What did they come in? Are they that much harder to find?
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • cooperman
            • Nov 2009
            • 219
            They came in some 5 and 6 series cars between '79 and 85' I think. The blocks have an "L" painted on the side, have an extra water passage compared to the M30, and the pistons are flat topped.
            They are pretty rare. You can build one if you punch out a normal M30 block to the same 93.36 bore (custom pistons) and have an 84 mm crank (found in S38b35). The cam is the same as stock M30b35 (though the part numbers are different). I actually have everything but a piston set to build another one.
            You could shorten the stroke further if you had an 82mm crank and went with custom rods and/or pistons. That motor would really rev.
            • cooperman
              • Nov 2009
              • 219
              Yesterday I spent 4 hours cleaning out the piston ring grooves.
              Set the ring gap- .014" for the top ring, .016" for the middle ring
              Installed the rings and the rods on the pistons
              Adjusted the valves- .012" cold
              Modified the oil sprayer bar, installed the banjo bolts with new cruch washers, loctite red, 9ft/lbs torque
              Installed oil filter canister to the block
              • cooperman
                • Nov 2009
                • 219
                Bumping this. Major updates coming.
                • george graves
                  • 20003
                  Don't bump! Pony up. Subscribed.
                  Originally posted by Matt-B
                  • george graves
                    • 20003
                    Originally posted by pandaboo911
                    M90 = sohc m88
                    Makes the same power as an m30b35
                    Euro L-block?
                    It's short stroke and larger bore make it like a m30 that is more lively. It's a very rev-happy, peppy motor. I know, I've driven an e28 with one that was built by M3Ryan. TQ is still there since the long intake is there. It also sounds different then a typical m30b35 - it sounds kinda mean to be honest. Going 20 MPH in a neighborhood, you would get people looking at you and "patting the ground" as if to say "slow down!"
                    PS - it's also commonly called a "euro L-block" Because of the letter L on the block. And was only gray markt for the US I think????
