Project Facelift
  • Jean
    • 18228
    #421
    Originally posted by backtrail69
    Just look at an 88...
    Good point, i'll look for one. I don't have the resources to do a full facelift swap but want to add a valance to my e30.
    • Jand3rson
      • 37587
      #422
      Originally posted by Teaguer
      Now if Josh could only get his actual face facelift coming along the world would be a better place . :p
      ZING!
      Whatchu talkin bout, Tigger...
        • 34827
        #423
        ZING!
        needs a bumper tuck. :giggle:
          • 37827
          #424
          Not a fan of the dual lip setup.
          Classic BMW Specialists
          Santa Clarita, CA
          www.BimmerHeads.com
          • Garageaholic
            Freestyle Fabricator
            • Dec 2005
            • 5204
            #425
            Def needs shadowlined glasses trim.
            Recent Rebranding!!
            E30 SM62/S62
            E30 M60 V8
            E30 M30 Big 6!
            Instagram.com/garageaholic
            Youtube.com/garageaholic
            • mikeedler
              • 6707
              #426
              I hate to say it, but damn, I think my daughter could do better welding than that!! JOSH???????!!!!!!?????????
              Prep work is 99% of the work follows along here too.
              You need to weld that thing completely on. Not that stitch garbage every foot. that is going to crack the bondo in a few months(I know you wont see it) BUT the rust will see it.
              sorry to be the neg one.
              • PiercedE30
                • Apr 2005
                • 4220
                #427
                +1 on not leaving the stitches. I know why your welder stitched it, but to leave the stitches and not do the complete seam? C'mon. When you are driving the rear valence will move a little from the wind and, hopefully not, a possible bottom out/uneven surface. That, and those stitch welds, will definitely cause the prep/paint to crack.
                Tell him to go to harbor freight, pick up their little flux-cored mig machine for 140, set the speed, low heat, and finish up that stitch welding.....please. And to keep the metal from possibly warping, throw a wet rag on the inside of where the welds are going.
                Jon
                My 2.9L Build!
                • Jand3rson
                  • 37587
                  #428
                  There will be no bondo applied to this area. The apron is mounted to the car with screws, and also with the shown welds. Again, Andrew is a great welder, the welder we were using is a piece of shit. There is no need to weld the entire seam. Back when I wasn't even going to weld it, everyone kept telling me I needed to weld it, and that I should just do small welds every few inches. Now I've done that, and everyone is telling me I need to weld the entire seam. Trent's apron is welded in the same way (probably with much better welds).
                  The apron is very securely mounted. The welds, thought they admittedly do look like shit, are plenty strong and are burned through. All of the areas of bare metal will be sprayed with self-etching primer, and the whole area up into the existing body in the bumper area will have rubberized undercoating reapplied, which will fill in the VERY small gaps, and then painted.
                  • trent
                    #429
                    miked and pierced, there is no reason to do an entire seam. I did my setup the same way, and it will be fine. IT isn't like there are cuts or riffs in the panel that will cause it to "prep/paint to crack"
                    This is more than acceptable. By your stupid theory cars should be seam welded, which they are not.
                    Besides, MORE welding could possibly mean MORE rust on the back side.
                    • mikeedler
                      • 6707
                      #430
                      think you know it all if you want, But I have seen plenty of SHAVED mini trucks in my days, and it all cracks. ask a REAL Body guy too, he will tell you that that stitching on an outside body panel is crap. I am not knocking either of you REALLY--- both cars are super clean, I just know from EXPERIENCE, that will suck up water, after it cracks in a few years and rust VERY fast. do what you all like, im just trying to be helpful.
                      • CleanAzzE30z
                        • Jan 2004
                        • 11794
                        #431
                        Stop instigating shit, negroe!!! ;) jk
                        Mariano
                        • mikeedler
                          • 6707
                          #432
                          actually, i just want attention!
                          • CleanAzzE30z
                            • Jan 2004
                            • 11794
                            #433
                            When Im in Germany again, Ill give you attention. ;)
                            Mariano
                            • Jand3rson
                              • 37587
                              #434
                              What are you talking about that is going to crack? The welds? I don't see that happening. And as far as the seam, it's not going to be sucking up any water because it's going to be sealed and then painted.
                              • AndrewBird
                                The Mad Scientist
                                • 11892
                                #435
                                Ya, I was the one welding them. Between the crappy Schucks welder and all the burning undercoating, they came out looking like shit. Good penetration, but they look bad. I really need to pick up a good welder, just don't have the cash.
                                Oh, it is a flux core welder, not MIG by the way.
                                And Mike, it will be fine the way it is. The whole thing is going to be undercoated and then painted so there will be no metal exposed to the elements for moisture to get to any of the metal.
                                And as far as cracking, the metal or the welds sure as hell isn't going to, so I don't know what you are talking about.
