Ryan's Hennarot 318is (s54, slicktop conversion, MT2)
  • rjmcdermott81
    • Oct 2014
    • 568
    #31
    Now, first step was to build up the valley where the roof/sunroof met. I didn't want to fill it with pure filler because I was concerned it wouldn't have the structural integrity required. I filled it first with "kitty-hair" or fiber glass filled polyester resin. Great stuff to work with.
    Build Thread: Ryan's Hennarot 318is
    COTM Aug 2019
    • rjmcdermott81
      • Oct 2014
      • 568
      #32
      mt2 arrives.
      My friend also suckered me into buying his 911 that I painted the spoiler for... I needed something fun to drive while waiting on this dang e30
      COTM Aug 2019
      • rjmcdermott81
        • Oct 2014
        • 568
        #33
        Filler, spread extremely thin. Lots of sanding
        I had to leave town and wanted to protect all that hard work so I epoxied the roof.
        COTM Aug 2019
        • rjmcdermott81
          • Oct 2014
          • 568
          #34
          I think I easily spent 100 hours on the roof, between removing the sunroof, welding in new panels, bonding in the sunroof and then leveling it all out. I'm sure a shop would have been faster but at a $35/hr labor rate in a body shop....I don't even want to think what would have been discussed if I had taken my car somewhere to be painted.
          Getting serious now, I pulled out the front/rear windshields. Much easier than I expected it to be.
          COTM Aug 2019
          • rjmcdermott81
            • Oct 2014
            • 568
            #35
            More roof work. There was a sizable dent near the windshield I couldn't get to so I had to fill.
            COTM Aug 2019
            • rjmcdermott81
              • Oct 2014
              • 568
              #36
              Prepping the car for 2k high build surfacer to block. Because my epoxy primer had cured already I had to scuff the entire car with 220 grit first, then lay down a coat of epoxy primer then 3 coats of surfacer. I used this opportunity to spot putty tiny imperfections.
              here it is painted
              Roof is starting to really come together:
              COTM Aug 2019
              • rjmcdermott81
                • Oct 2014
                • 568
                #37
                Test fitting the mt2 rear bumper. I hate the fit...may try to do what Jordan did with his build. Or, I'll have to modify the tip.
                Hours and hours of guide coat/blocking/more primer/blocking, repeat
                COTM Aug 2019
                • rjmcdermott81
                  • Oct 2014
                  • 568
                  #38
                  Time to start painting! At this point, all the body work is done, car has an body work done, epoxy primer, followed by 2k surfacer blocked with 400 grit.
                  As a first test I painted the inside of the trunk.
                  Entire trunk based
                  Edge cleared
                  Done
                  COTM Aug 2019
                  • rjmcdermott81
                    • Oct 2014
                    • 568
                    #39
                    Now to paint the body. I wanted to seal the entire thing with an epoxy sealer just for extra precaution and longevity.
                    Car taped and ready for sealer
                    Sealer coat done
                    I let the sealer cure for 1 day and then retaped the entire car (didn't want gray flecks to land on the red paint).
                    Had to sand a couple nibs
                    First coat of base
                    Base done
                    Action shot after laying down all the clear - notice the stack of air filters in the left corner I went through to keep all this paint from going out and pissing off the neighbors. Also, that is not the respirator I'm using while painting. I used a Hobby air 400 that supplies fresh air through a hose to a mask. Really great setup because you know 100% that you're breathing safe air. Respirators can't block out isocyanates.
                    COTM Aug 2019
                    • rjmcdermott81
                      • Oct 2014
                      • 568
                      #40
                      Here is the car the next day after painting
                      After going through this, my take on car painting is:
                      1. It's going to take forever so you better love it.
                      2. Follow every instruction perfectly. It's science not art.
                      But, even with all that, I'm still a total novice so there is a ton of work wet sanding the clearcoat to flatten out the orange peel. But in the end...after a wetsand and buff it looks like a million bucks.
                      First test. Here is the fender before cut and buff
                      After (this isn't final - just a quick test)
                      Tons of wet sanding on the roof so I put my helpers to work
                      and man...check out that roof!
                      COTM Aug 2019
                      • kid8
                        • Jul 2013
                        • 312
                        #41
                        I'm so happy you finally made a build thread lol. Looking awesome, keep it up!
                        • rjmcdermott81
                          • Oct 2014
                          • 568
                          #42
                          I'm not sure if I should thank you or curse you for sending me that clist ad for the car... but it's been a fun journey. Thanks for the help.
                          COTM Aug 2019
                          • zwill23
                            • Jul 2015
                            • 615
                            #43
                            Awesome!! Very impressed with all the work you've done, I'm excited to see it on the road!
                            • jeenyus
                              • Aug 2011
                              • 2064
                              #44
                              Something special about seeing a new thread and seeing 3 pages of content within the first 2 days of posting it. Great work! Looks like a great project and I love that the kiddos are helping.
                              • FredK
                                • 14762
                                #45
                                whoa, this build is awesome!
