So you are getting eaually incredible body work from this? There will be a thread on that too?
S14b23 Drivetrain overhaul and concours restoration.
https://mtechniqueabs.com/
They were cleared of the major grime in a parts washing tank at the shop, then bead blasted to remove the baked on crud, then vapor honed to restore the smooth surface sheen.Tenured Automotive Service Professional - Avid BMW Enthusiast
Exhaust valves are trash, throw them away and buy new.
Penny wise, pound foolish to try and save them. You're installed heights will be all sorts of messed up by the time you re-cut the valve seats and then those valves.
With new, you can set installed height correctly, once the seats have been re-machined.Below the radar...
Originally posted by unhcll View Postexhaust valves are trash, throw them away and buy new.
While I certainly don't disagree my responsibility to this point is disassembly and cleaning. I fully intend to let my machinist determine what is usable with recon and what needs to be replaced. Valves are about $25 each, no big deal if needed.Tenured Automotive Service Professional - Avid BMW Enthusiast
Originally posted by Jordan View PostThey were cleared of the major grime in a parts washing tank at the shop, then bead blasted to remove the baked on crud, then vapor honed to restore the smooth surface sheen.
I've not had an issue with it in the past, especially followed up with vapor honing. I wouldn't run a just bead blasted piston though, even super fine media leaves them rough feeling.
I'm also not really expecting I'm going to be able to use the original pistons, its likely the block is going to need more love than they can allow. Again yet to be seen. The entire bottom end is at the machine shop now and I'm awaiting work on the suck I'll have to deal with.Tenured Automotive Service Professional - Avid BMW Enthusiast
The block will be fine, but I'm pretty sure it is going to need more than a dusting with a bore hone... which means in all eventually new pistons. Again we'll let the machinist say whats what. The client prefers to reuse original parts wherever possible, and so does my wallet, but if the pistons need to be replaced it is what it is.Tenured Automotive Service Professional - Avid BMW Enthusiast
Awesome work! Hope you guys are doing good down there. This is Kyle's friend, Paolo. We took a couple classes together in Texas. Do you still have the F10 or did you get another one?!clutchCTRL!Move with a purpose.- 1991 325iX 4dr/5spd- 1976 2002 SlickTop/2.7i M20/G260- 2000 323i AT2016 Mazda CX3 Sport AWD
Oh hey Pablo, yeah right after we met at the Gaylord convention center and I got back home some fuckwad kid with no license playing on his phone ran a redlight and tboned my F10 535i. It was a total loss. Multiple airbag deployment, left front hit hard, frame rail shifted, subframe and engine mounts broken. Left rear door and quarter hit too.
That's alriiiight though as I upgraded to a M5 instead. Tuned to 780hp/730tq daily driver mode :-) I had to replace 2 barrels and 1 face but was able to salvage my custom wheels.
Originally posted by UNHCLL View PostExhaust valves are trash, throw them away and buy new.
The valves can be tipped to correct height, provided there is enough margin. Hard to tell how deep the pits are in the pics, specially contrasting with the polished surfaces. More so, the seats would be a bigger concern (on a performance stand point) since the further they go into the throat, the worse low lift flow will get.
I have seen some real crap valve jobs come out of local machine shops that just care about the engines running, hence the reason I purchased a valve machine and moved the work in-house. Nothing worse than getting some nice flow numbers on the bench, just to have it ruined by a yocal.
