What did you do to your E30 today?
This is a sticky topic.
  • ethrtyiS
    • 8147
    #2401
    Wash and waxed it and gave it good detailing.
    '89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5
    my feedback thread
    • DTM190
      • Nov 2008
      • 1107
      #2402
      On the mrs 320i auto 4dr come 325i manual,
      Fitted head unit
      Replaced front rhs power regulator
      Finished putting interior together
      Replaced front brake hoses
      2 front tyres
      Polished scratches out of windscreen
      New wiper blades
      secured battery
      ready for roadworthy certificate 2nd test and rego now :)
      Originally posted by der affe
      first try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
      if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.
      • pharow
        • Jul 2010
        • 1021
        #2403
        well 2day i hope i fixed a fuel problem. pulled my fuel pump and made sure tht it was not clogged. then took it out and ran her up to 110 mph. just to check it out. then i kept driving to check mpg. i got up to 29.4mpg accourding to the computer.
        a few wks ago i pulled my ac compressor, the cruise control, and the dead weight in the trunk. im kinda new to this car, so if anybody can give sum advice...thanx.
        '02 Outback wagon
        '87 325is 5sp
        '93 Kawasaki ZR1100
        • SeriousBusiness
          • 428
          #2404
          Wash and then quick spray wax. Spent more time cleaning those gottverdammte weaves than anything else. They are mint though!
          1985 RX7 - Badassery Exemplified.
          1989 325is
          -Tom
          • dr.strangelove
            • Jan 2005
            • 847
            #2405
            took the ix to the muffler shop. NO MORE CAT!!!!! sweet.
            • GANSTA
              • 69
              #2406
              Did some polishing and waxing and guess what! I found out you can polish a turd :)
              I also rolled the guards with my new favorite tool.....a guard roller.
              • JT325is
                • Oct 2009
                • 1242
                #2407
                wiped off some birdshit after i just washed today too!
                • White325is
                  • Oct 2006
                  • 5947
                  #2408
                  Made a new intake setup.
                  • agustingig
                    • Dec 2009
                    • 140
                    #2409
                    Cranked over my M50B25 for the first time!!!
                    • freeride53
                      • 11972
                      #2410
                      Installed my new Blaupunkt. ill.
                      1983 Peugeot 505 STI
                      1992 Volvo 240 Wagon
                      • pharow
                        • Jul 2010
                        • 1021
                        #2411
                        i drove it to wrk, then i drove it home, then i drove it to buy things for a tune-up. thts is about it.
                        '02 Outback wagon
                        '87 325is 5sp
                        '93 Kawasaki ZR1100
                        • Jand3rson
                          • 37587
                          #2412
                          Removed the washer spray nozzle lines from inside my hood, and started fiddling with a way to fill the holes.
                          • jasonsnoddy
                            • 1900
                            #2413
                            filled it up, $42
                            Originally posted by stewie30luvr
                            ooo cause i was fixing my chain tensioner and there was a black widow on the radiator so i killed it
                            Originally posted by JakeP
                            with a coathanger
                            • archie
                              • 5448
                              #2414
                              Went and visited her at the upholstery shop.Getting all new leather interior.
                              88 M3 Diamantschwarz
                              89 M3 Zinnoberrot
                              56 Isetta
                              LIKE ARCHIE'S on Facebook!
                              • E30is90
                                • Jul 2010
                                • 107
                                #2415
                                1. Replaced OBC light bar.
                                2. Replaced lights behind fan speed dial, temp dial and above headlight/fog light switches.
                                3. Reconnected chime module.
                                4. Adjusted brake light switch to not intermittently stay on when not pushing down brake peddle.
                                5. Installed replacement caliper bleed screw caps after flushing and replacing brake fluid a few days ago.
                                6. Replaced tranny and diff fluid a few days ago.
                                7. Removed and cleaned air intake muffler, air filter, intake bellow, ICV, mopped up years of sludge.
                                8. Reconnected fuse 15 for heated seats (not that these are needed for a while).
                                9 Tomorrow- replace both cracked fog lights!
                                over 240,000 miles served
                                original owner since Oct. 31, 1989
