What did you do to your E30 today?
This is a sticky topic.
  • twism
    • Sep 2006
    • 359
    #2536
    I didn't really do anything to it, but I got the cams for it yay :D
    • Reap3r
      • 596
      #2537
      I drove it to work. And I managed to shoehorn a benchtop inside it because my daily is still broken :(
      Turbo M42 Build thread:
      http://www.r3vlimited.com/board/showthread.php?t=169672
      • kuuki
        • Sep 2006
        • 63
        #2538
        Swapped rear tires from side to side..
        Now I have something to burn :D Thankfully I can put winter tyres in end of next month.. Should first find a good set of style 5.
        The red E30 320i '88.
        • MikeDE
          • 1873
          #2539
          Sold it's M50/G250 b/c i'm broke.....and cleaned it for a meeting later, pics to follow
          -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
          • Jalves619
            • 596
            #2540
            Started yesterday with an oil change, new front rotors and a complete retorque of the front suspension along with a set of spacers to keep my dsII's from rubbing. Today hopefully I can get the camber/toe adjusters welded on for the rear so I can finish the 5lugz.
            • lga714
              • 315
              #2541
              Preparing my S50 ;)
              mtechII 5 lug S50
              • Jand3rson
                • 37587
                #2542
                I'm giving some serious thought to considering thinking about going out to the garage, and beginning the task of masking off my front and rear windshield seals so I can PlastiDip them.
                • Dave
                  E30 RAT
                  • 11675
                  #2543
                  1. Did a stomp test on it to determine the cause of a CEL/warm rough running/misfire condition.
                  2. Found it to be code 1252 "fuel injectors"
                  3. Bought some CRC electrical contact cleaner and some dielectric grease.
                  4. Went to inspect/clean the C101 under the intake - found it to look okay, cleaned it anyway, and found that the half mounted to the metal bracket thingy was not mounted properly - such that when it was connected, it was not a 100% tight fit. Remedied that, hit the contacts with some dielectric grease and snugged it up.
                  5. fired it up - ran it well past the point where I had been having the problem and it ran like a charm. Hoping I found and fixed my problem.
                  6. Ordered a new center emblem for my steering wheel and a cheap Chinese knock off wheelskins kit on eBay.
                  Current Cars
                  2014 M235i
                  2009 R56 Cooper S
                  1998 M3
                  1997 M3
                  • straight6pwr
                    • Sep 2004
                    • 3450
                    #2544
                    new chrome front kidneys, painted tail lights red.
                    • Dolmangar
                      • Jun 2010
                      • 95
                      #2545
                      Over the past few days:
                      1. Replaced front sway bar end links - Completely worn out.
                      2. Replaced tie rod end bolts - both were stripped and clunking because they couldn't be tighted
                      3. Replaced Oil Control Valve - Completely stopped leaking oil!!!!
                      Easy but PITA job at the same time - nothing like laying on your back with a spring loaded cover and a spring clip pointed at your head.
                      4. Passed Va Safety and Emissions Inspections on the first try!
                      Now Road Legal! - I bought the car about 2 months ago and have been working on it to make it a weekend car / nice weather DD. Hope to start driving it to work a few times a week now that it's a bit cooler (no AC...yet).
                      • Cyrix2k
                        • 593
                        #2546
                        removed the hood, removed boost, and removed the grills & kidneys. I'm trying to fit a volvo 740 intercooler and it's being a pita.
                        1997 540i/6 - stock
                        1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
                        1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
                        • Charley
                          • 396
                          #2547
                          Cleaned and painted my diff, still need to clean the cover and press in the
                          poly diff bushing
                          • pharow
                            • Jul 2010
                            • 1021
                            #2548
                            found out tht one of my spark plugs was loose. i dont know how tht happened. all good now.
                            '02 Outback wagon
                            '87 325is 5sp
                            '93 Kawasaki ZR1100
                            • Jand3rson
                              • 37587
                              #2549
                              Well, thinking about it got the best of me, and I got bored. I started masking off my windshield seals so I can PlastiDip them. They're faded and gray-ish, and they make the whole car look bad (to an anal OCD sufferer like me).
                              • kamotors
                                • Nov 2007
                                • 7102
                                #2550
                                ordered brembo brakes for all four corners, time to get rid of my glazed rotors.
                                7speedshop.com
