Chased gremlins, got my oil level light to work, removed and cleaned ICV and TB cleaned up the engine bay and broke the fuse box cover. Damn
What did you do to your E30 today?
This is a sticky topic.
Could be better, could be worse. -
Got both my new axles in. Easiest car to swap axles on for sure 20 min a side.84 318, 86 325ES, 85 325E. 89 325IS,
89 BMW 325is Turbo - 8.02@85mph 1/8th
90 VW Golf, 01 VW TDI Jetta
98 VW GTI VR6 - 11.679@117.58mph Timeslip
96 VW GTI VR6 - 7.63@97mph
www.lugtronic.comComment
Ordered a purge valve, picked the wheels up from powder coating and took them to get mounted and balanced. Picked up seat belt cover(goes over 17mm bolt), weather stripping around drivers side door frame(I need drivers side inside door sill), A/C lines, receiver dryer, rubber plugs for wire holes(cruise control, SRS, ...), C101 electrical boot, and tweeter for drivers side.How to remove, install or convert to pop out windows
Could be better, could be worse.Comment
Ordered a SR440X starter....joy now the waiting begins.Comment
removed front clip/ rad support (who needs this anywho?) lol-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
-The Beauty in the Tragedy-
MECHANIC SMASH!!- (you all know you do it)
Got Drop?? ;-)
Originally posted by JinormusJBut of course
E30s are know to be notoriously really really really ridiculously good lookingComment
[ATTACH]74384[/ATTACH][ATTACH]74385[/ATTACH][ATTACH]74386[/ATTACH]https://www.forabodiesonly.com/mopar...re-irs.356333/
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.Comment
Started tearing out electric's. In preparation for new engine.Comment
Bought a driver's side door sill.How to remove, install or convert to pop out windows
Why paint when you can plastic
Hi I'm new to e30s and I'm really enjoying reading all the post and taking in as much as I can at once... I started with a really bad paint job and just wanted to cover what I had while I was fixing up the car and driving around ... I stumbled on a product call plastic dip has anyone ever done this or know anything about it ?Comment
Got my wheels on, with new tires. Put the ICV and TB back on. And picked up my trim that is freshly powder coated.
-E3oswapme-Plasti dip is a really interesting product. There is lots of information on it's uses. I have seen a lot people use it to shadow line their E30's and other BMW's trim. Search on you tube and you should see a bunch of different application uses. The best part about plasti dip is if you don't like it, peel it off. But it is not really easy to peel off.How to remove, install or convert to pop out windows
rad support is now removable :) yeuss
now working on enlarging the inner fenders for better low with meaty tires-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
Got Drop?? ;-)
