tried to hammer out the bends in the shitty wheels i got in a trade
What did you do to your E30 today?
This is a sticky topic.
Got a set of new cloth seats and cleaned all the shit out of them.
1991 Alpinweiß Sedan.... mah mistress. <-click :pimp:
I got my pop outs in the mail. I am just waiting on the last of my trim pieces to install them.How to remove, install or convert to pop out windows
I got my a/c pulley in the mail today. It was bent to hell. Waiting for my new new a/c pulley in the mail.How to remove, install or convert to pop out windows
Made myself a sweet bass control knob.
My amp doesn't have a control knob or any plug for one, so I had to use an RCA inline one. I used the PAC LC-1 that ended up fitting so perfectly! Recommended if you need to use one. It was a gamble when I bought it... but only a $10 gamble. Works great!
Started with a pac lc-1 and its knob, and the trusty e30 blank plate!
Dremeled out the guts, drilled a small hole in the plate for the knob to pass through. It was then held on by a nut, very simple
As you can see, perfect fit!
Doesn't look out of place next to the radio, maybe next to all the e30 stuff though.. oh well. It would've been cool to make it out of the factory fader, but I didn't really have the space to do it, and that fader is being used as an aux fan switch. (also yes I know I need the trim ring for the radio, it's on its way to my house now)
Tried to put on my steering wheel. I found out I need the spacer and a quick release. So I cleaned up some wiring. Waiting on parts.How to remove, install or convert to pop out windows
Started putting my A/C together. A/C bracket is installed. The two bolts that go behind the harmonic balancer are a PITA to install without removing the harmonic balancer. I didn't feel like having to torque the crank bolt 300 ft/lbs. Is that right? Is the crank bolt the Jesus bolt and do you torque it to 300 ft/lbs? E36 S50B30How to remove, install or convert to pop out windows
