What did you do to your E30 today?
This is a sticky topic.
@rzerob.... what happening with fusebox?88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
Originally posted by burkey001 View Post@rzerob.... what happening with fusebox?
Originally posted by rzerob View Post
About 4 or 5 months later I noticed a few electrical issues I didn't have before, such as when I turned my headlights on it would shut off my OBC and radio temporarily. Then the car sat for the winter. I was in the process of installing an additional puller fan for the AC and when my high speed fan would come on it would kill power to half of my car including headlights, radio, fan, HVAC... So I went about diagnosing it and found the issue in the fuse box.
When the wire melted to the constant hot and melted the relays it also was burning so hot that the solder on the pcb of the fuse box started drip off and actually unsoldered itself. I had an extra fuse box so I just swapped it. I put in a pcb from an 89 because I plan on running ellipsoid head lights and the 89 pcb is made for that.
Here are a couple pics of the damage of the pcb board I replaced. You can see where the solder was melting. There was a puddle of solder at the bottom of my fuse box.
I finished the install of the front coil-overs and E46M3 brakes and 5 lug. I also installed my motorsports wheels studs, bled the brakes, diagnosed and fixed my low beams.How to remove, install or convert to pop out windows
I installed my rear coil overs, installed my front and rear strut bar, shadow lined the drivers side with SEM over top my faded powder coated trim, installed the hose from the intake to the icv, installed a new purge valve, installed my Seattle circuit fuel correction device(http://www.seattlecircuit.com/), installed my plate filler after I painted it with SEM, and washed it. This was all in the last two days.
is there any track record of the towers breaking through with that setup on the rears? I'm just thinking the tower was only ever designed for the load of the shock absorber, but now the whole suspension lives on that point now. I much prefer that setup as there would be far less squat.Last edited by bangn; 06-28-2016, 07:08 AM.Boris - 89 E30 325i
84- E30 323i
Originally posted by bangn View Postis there any track record of the towers breaking through with that setup on the rears? I'm just thinking the tower was only ever designed for the load of the shock absorber, but now the hole suspension lives on that point now. I much prefer that setup as there would be far less squat.How to remove, install or convert to pop out windows
Finalised the tune of the S54.
Saturday night I did my third timing belt and second water pump since 2012. Definitely getting better at it. Last time I had a bitch of a time getting the belt on... This time I used this plastic clamps to hold the tension on the belt... Literally took me about two minutes.
Not sure why people have big issues with aligning the hood... I put the back end of it on the rails, like when you first open it... My buddy made me these studs to line up the brackets, and I get the first bolt in and test the movement. If it slides in nice and opens the same way, I tighten the rest down. I've removed the hood twice now on my own and the reinstall has been great both times.Estoguy
Current Cars:
2016 PORSCHE GT3 RS
2017 FERRARI 488GTB
2018 RAPTOR CREW CAB
1991 318is SLICKTOP H&R SPRING SEMA CAR
1991 318IS SLICKTOP STERLING SILVER
1990 325ic BRONZIT/AUTO :)
1989 E30 M3 (SOLD AWAITING SHIPPING)
On Order:
2018 DODGE DEMON
Searching for:
CLEAN E30'S
S54 DRIVETRAIN
E30 DASH
E30 PARTS
