What did you do to your E30 today?
This is a sticky topic.
    Jebus, I suck at posting photos. Sorry.
      Replaced rear trunk shock and adjusted the trunk to be flush when closed. With a new shock installed there was upward pressure on the drivers side that pushed the trunk up just a little bit. Adjusted the center bracket thingy to bring the trunk down a tad more when shut. Its so weird having the trunk pop open now when I press the button to open it.
      Then remounted my trunk tool kit and found that I need the foam rubber that holds the tools in and keeps them from moving around.
      To continue with the trunk I installed an ammo can by drilling through the bottom of the ammo can and the plate that covers the weight in the rear passenger side of verts. Bolted it down and this will be my tool box. (Need to figure out which tools would be best to keep in there) . Made sure that the clearances were dialed in so It could be opened from the front and would not hit the inside of the trunk and not open all the way.
      Made a holder for my CR7 rim center caps, rings, and retainers. 3 D Printed the holders and bolted them down to a piece of siding covered in grey fabric. This will allow me to pull the center caps, rings , and retainers and store them when not on the e30 vert. These parts are NLA and kids (thieves) like to pull arbitrary items for the hell of it so not taking any chances with these.
ID:	9912798 Click image for larger version
      Somehow I am missing a small C Clip that holds the cable in the trunk to a pin . It keeps the cable in place and that cable disallows the trunk and convertible top boot to be opened at the same time. If anyone has one of these small clips they can spare please let me know.
        Originally posted by quasi mofo View Post
Name:
        Who is Alex? Looks like some great work.
          Alexander Lenz.
          BMW E30 – Exklusive Innenausstattungen Die BMW 3er Modelle der Baureihe E30 sind auf dem besten Weg zum Klassiker. Leider ist der langjährige Alltagseinsatz an den meisten Exemplaren nicht spurlos vorüber gegangen. Unsere Passion ist die Wiederherstellung der inneren Werte. Wir sind
          bmw-leder.de, Zella-Mehlis. 2,509 likes. Impressum: Alexander Lenz, Gabelsbergerstrasse 19, D-98544 Zella-Mehlis, E-Mail: info@bmw-leder.de, Telefon: 0176/22152036, Steuer-Nr.: 171/244/07990
            I second that Alex did most of my interior except the seats.
              I wrapped my own console with leather covers I purchased off eBay. My job looks decent, but definitely is nowhere near Alex' quality. I think I'm going to buy a console from him the near future.
              Unfortunately, he can't ship dashboards from Germany anymore.
                Wow....this is what I need in my life.
                Contact him via Facebook?
                  Either facebook or his personal site.
                    Added some sound damping and replaced the vapor barrier and door card on the passenger side today. Will get the other side done tomorrow.
                      Updated the interior with some Toof.
                        ​​​Installed the Thumbscrew /Bolt for the rear jack hold down. Found some local e30 Hoodrats that were parting a coupe and pulled it. Blasted and powdercoated my crank pulley, water pump pulley, and bolts.
                        Still need to source a harmonic balancer and lower timing belt cover to install these though.
ID:	9917356Click image for larger version
                          Swapped ignition wires from an E28. Happy EEE-ster! Click image for larger version  Name:	 Views:	0 Size:	38.4 KB ID:	9917400
                            Installed my new custom shift knob.
                              Howd you attach that?
                                The ring at the bottom of the knob has set screws you use to secure the knob to the shifter rod.
                                I made a custom order with Built by Basil.
