My e30 DTM car copy build
  • Teaguer
    • Sep 2004
    • 6167
    Originally posted by Major
    I struggle to see the logic behind giving any female a Hummer, or a 4x4 for that matter. :p They are the greatest peril on the roads today.
    Yes , I prefer women giving me hummers .
    • Mike B.
      • Jan 2006
      • 987
      Very nice work! I am looking to create a similar design when I install my cage. I like the way you are tying in the diff and rear subframe mounting points.
      • M42Technik
        • 9781
        I miss "bumbners"
        Subscribed.
        Reminiscing...
        • redbull 325is
          • 7471
          Let's set this straight
          bnumbners is NOT chicken wire boy.
          Bnumbners = erick/rwdrift picking up myspace chicks
          Chickenwire= some random toolbag with teh razors suspension.
          teaguer: we got the joke on the first post :-*
          and on the subject of reinforcing the rear shock mounts: I agree, it even lends the possiblity or running true rear coil overs down the road.
          Julien
          Build Threads:
          • ///meric
            • Jun 2004
            • 124
            heres some photos of the driver A pillar bar. Hopefully this week i Get the sheet metal gussets fabricated so that the drivers side door car wil be completly done.
            The Subframe tie in is almost done.
            I wanna go Fast
            • MikeK
              • Jan 2005
              • 2771
              so why an S14? Im curious to why you chose that motor as suppose to other common swaps that are available?
              Toyota Pickup
              • Bill-B
                • Apr 2007
                • 1242
                Damn, you have been workin' you ass off since I saw it last...
                and this project is legit, not any of that chicken wire bullshit...
                Originally posted by NavyE30
                I saw Vlad was posting and got excited. Then I saw there weren't any boobs and was sad.
                • ///meric
                  • Jun 2004
                  • 124
                  Originally posted by Janissarie
                  nice project bro, looking forward for more pics
                  who is bending and welding for you
                  The welding is being done by me
                  Since everyone knows im going to be running ap racing brakes a balance bar is needed. So im going to be running floor mount pedals too. AS bill stated no corner will be cut and I'm building everything to a very high standered
                  Mainly becuase i want to learn the car before i go for crazy power levels. Its getting built and should be putting down between 250 and 275 wheel. Carbonfiber airbox. MS cams, JE dtm copy pistons. Knife edged crank, and if i can located on over next summer a Grp A Cylinderhead. Dry sumped motor, with a custom front subframe to lower the motor I should then be putting down 275 wheel hp easy and since the car will weigh less then 2200 LB it will be more then fast enough.
                  Right now im more concerned with getting the car built then dialed in. Once thats done i will do a DTM tubular trailing arm set up with adjustable rear roll center, and cockpiut adjustable sway bars. Then i will start building a bmw v8.
                  I wanna go Fast
                  • UNHCLL
                    • 8790
                    I'd like to buy this, except seeing the rollbar being bent by driving over it with a car removes all credibility.
                    Below the radar...
                    • FredK
                      • 14761
                      ah ok, my bad. ///meric is NOT the dude in CO. He is the guy who posted pics of AP racing calipers not fitting into a bottlecap wheel, saying they were the brakes we want, but cannot afford.
                      Well, good luck with your project.
                      • Charlie
                        kid tested, administrator approved
                        • 6686
                        VSR uses a range rover, don't they?
                        -Charlie
                        Swing wild, brake later, don't apologize.
                        '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                        FYYFF
                        • matt
                          • 3732
                          -Charlie
                          We use only the finest German hammers and blowtorches to bend tube.
                          The design of the cage looks decent (you obviously picked a good design to copy) but... work on your fabrication techniques. It's totally unacceptable to weld a tube straight to the chassis. (there are exceptions to this, but not where you did)
                          You probably shouldn't be using 4130 either...
                          • FredK
                            • 14761
                            Is there anything wrong with 4130, as long as you GTAW it?
                            • 4ce30
                              • Feb 2006
                              • 2762
                              gnarly!
                              -Brandon
                              • matt
                                • 3732
                                It's overkill. There is a really good discussion of metal selection in Engineer to Win by Carroll Smith.
