★★★★George Graves★★★★ Project Blog for e30 Gizmos and Gadgets - 2025 UPDATE
  • NC325iC
    • Mar 2004
    • 6565
    #76
    if you still need more switches contact rigmaster
    • SamE30e
      • Sep 2007
      • 4319
      #77
      ^typical...$600 in gauges, 20 year old Blowchunks pullout deck
      Those gauges are like 60$ each lol. I had them in my jetta.
      1985 325e 2.8 Turbo VEMS
      • george graves
        • 20003
        #78
        I got some switches in for more testing and mockups
        I'll try to get some more updates before I leave for vacation.
        Originally posted by Matt-B
        • So Live
          • 2512
          #79
          Awesome dude. Like i said, lemme know when your ready to sell some. I can send you my defrost switch too if you need a "core". I may have an extra that does not work too.
          Im sure many people like myself, have no problem buying the sending units seperately too.
          Keep us updated!!!!
          Chris
          -Chris
          • AndrewBird
            The Mad Scientist
            • 11898
            #80
            What the hell is that switch on the end, right side?
            • george graves
              • 20003
              #81
              I want to say it's an e36 ASC switch.
              • So Live
                • 2512
                #82
                OH hey, have you decided on a printing method if any yet?
                -Chris
                • george graves
                  • 20003
                  #83
                  No - I don't have plans to do any printing on these. I don't think it will be an issue either - unless i hear otherwise.
                  • uofom3
                    • Jan 2004
                    • 5392
                    #84
                    George amazing work. I'm really impressed. When you have something figured out in the shift light department I'd be very interested tos ee what it looks like. I already have AFR/oil temp/pressure/voltage/egt.... so I'm low on other needs but this stuff looks fantastic and I love the OE look!
                    PNW Crew
                    90 m3
                    06 m5
                    • Mtriple
                      • 3139
                      #85
                      I'm watching patiently as well. Keep up the good work gg.
                      Originally posted by Simon S
                      • Sean
                        • 5793
                        #86
                        How's this comin, GG?! I'm really looking forward to this and am very interested in acquiring these from you someday! :)
                        - Sean Hayes
                        • george graves
                          • 20003
                          #87
                          Working on them occasional. I don't think they will be a huge seller, so it's not very high on my to do list. I have some other cooler project I'm into now.
                          I'll post up more when I can.
                          Thanks!
                          • alexw
                            • 1140
                            #88
                            ^^^ Bump.
                            Also interested.
                            alexw
                            (2) E30 tourings - sold, E30 M3 - sold, 89 325ix sedan, 91 318is slicktop
                            Wisconsin Members!- Join WiBimmers.com, Wisconsin's BMW community.
                            • george graves
                              • 20003
                              #89
                              Doing a bit more work this week on them as I found some free time. I think I might make a voltmeter my first real for sale item. You'd be amazed at what you can learn about your car once you know how much voltage the entire system is seeing.
                              In the mean time - buy an OBC temp sensor - it's a great way to fund more e30 projects like this.
                              • george graves
                                • 20003
                                #90
                                OK - I now have two gauges completed.
                                One is a voltmeter, the other a Narrow band AFR. Both are "plug and play"
                                Voltmeter:
                                - Measures very accurately from 10.5 volts to 15 volts in 0.5 volt increments.
                                - Only will require two wires to hook up - power and ground.
                                LED 1 10.5 volts
                                LED 2 11 volts
                                LED 3 11.5 volts
                                LED 4 12 volts
                                LED 5 12.5 volts
                                LED 6 13 volts
                                LED 7 13.5 volts
                                LED 8 14 volts
                                LED 9 14.5 volts
                                LED 10 15 volts
                                AFR(air-to-fuel ratio) gauge:
                                - Gives you a ball park measurement on how your car is running. Will warn you about a dangerous lean or rich condition.
                                - requires Power and ground
                                - no need for a second O2 sensor, you can tap your existing sensor. (if you want to know why this is possible - it is because my unit has a huge impedance rating - in the +20 Mega-Ohm range
                                - AWFUL for tuning a turbo - so if that is what you are doing right now - please don't buy one.
                                LED 1 REALLY LEAN
                                LED 2 REALLY LEAN
                                LED 3 REALLY LEAN
                                LED 4 LEAN
                                LED 5 GOOD RANGE
                                LED 6 GOOD RANGE
                                LED 7 RICH
                                LED 8 REALLY RICH
                                LED 9 REALLY RICH
                                LED 10 REALLY RICH
                                (If you know narrow band AFR gauges - you'll understand why I listed the values as I did)
                                The only last one I'll will make with this design is a WIDEBAND air-fuel ratio display. It will require that you already have a wideband o2 and an LC-1 or the like. Other than that it will plug into the second output of the unit and only require power and ground.
                                The oil pressure, boost and others will require a slightly smarter design. So that's in the works as we speak - plus a few other surprises!
                                Please post up if you are interested in either the volt meter, or narrow band AFR gauge - I'll include that in my next parts order...
