m21 swap underway
  • rs4pro3
    • 5808
    m21 swap underway
    Well it's not fully e30 related, but close enough
    I recently picked up a rust bucket e28 turbodiesel, so i'm yanking the engine out of it and dropping it into my straight 86 528e. Plus i'm going to throw a 5-speed tranny on while i'm at it, on to the pics.
    cut the core support out to make yanking the diesel easier
    Diesel out and on the engine stand
    I swung by the junkyards yesterday and got all the parts I need for the 5-speed conversion minus the radiator. The biggest thing to over come is the flywheel.
    On the Turbo diesel there is a sensor directly below the starter that reads 6-pins on the back of the flywheel to generate the tach signal. So I set about adding these pins to the back of a standard single mass m20 flywheel.
    Old Auto flex plate showing the 6-pins
    Pins removed
    Pretty little pins
    set the Auto flex plate on top of the 5-speed flywheel and lined up all the bolt holes to drill the holes for the pins
    Here is a shot of the sensor that reads the pins
    Holes drilled
    Pins pressed into place
    More to come later
    And here is the new home for the oil burner
    85 325e 2.7 ITB'd stroker
  • 2002maniac
    • 4260
    cool!
    • Lazr111
      • May 2007
      • 340
      Looks like a bad ass project. Good luck man, and I hope everything works out flawlessly.
      If life passes you by... Downshift.
      • So Live
        • 2512
        bigger turbo and more boost!!!!!!!!!!!!!!
        cool project though
        -Chris
        • Dave
          E30 RAT
          • 11675
          WVO going to be used?
          Current Cars
          2014 M235i
          2009 R56 Cooper S
          1998 M3
          1997 M3
          • redbull 325is
            • 7472
            few tips for the m21:
            1. if you replace the timing belt, just mark the old one with white-out as there are no TDC marks
            2. Get an intercooler these heads LOVE to warp (a new water pump is also worth it's weight in gold)
            3. Once everything is running solid, crank up the diesel pressure and the boost!!
            I'm skeptical about the flywheel.. these motors came stock with mamoth dual mass flywheels to smooth out the motor, I *hope* the I f/w is heavy enough to make it an OK dd.
            Julien
            Build Threads:
            • EtaSport
              • 2853
              nice.. im suprised you still have that car. where did you end up finding an oilburner?
              Old and improved:
              • rs4pro3
                • 5808
                Intercooler already in the works(going to use a 745i unit).
                Water pump is 2 week old
                I'm using the 24lb eta single mass flywheel not the I, so it should have enough mass to it.
                Long story short the oil burner has been in my driveway since last may, but I just recently purchased it from it's owner.
                Dave I'm just going to run regular diesel in it for now. I may later do a veggie oil conversion but depends. I'm trying to make a decent daily driver so this engine won't be getting anything to radical. The red car is a decent driver but the head and or block is cracked and it overheats when sitting at idle.
                Here are some pics of the 5-speed stock pile of parts.
                I had been saving the tranny for this engine, but it needs a full rebuild
                • Dave
                  E30 RAT
                  • 11675
                  Keep us posted. A guy here locally runs vegetable oil in his late model VW and MB diesels. He has a "refinery" in his garage and gets his supply from a local Chinese place. He showed me the setup when I was looking at a 2002 he had for sale a while back.
                  Current Cars
                  2014 M235i
                  2009 R56 Cooper S
                  1998 M3
                  1997 M3
                  • alpinaclone
                    • 820
                    Great project. I have always wanted to throw a m21 into an e30. I think with a little more boost it could be a really fun and unique daily driver.
                    Matt
                    • ldsbeaker
                      • Aug 2004
                      • 3098
                      I want one...
                      Slicktop City!
                      • redbull 325is
                        • 7472
                        and it'll sound just like an F-350 powerstroke *sigh*
                        Build Threads:
                        • EtaSport
                          • 2853
                          ha, i drove a TDI jetta today and they do sound like diesel trucks, i dig it though.
                          Old and improved:
                          • rs4pro3
                            • 5808
                            I did a little tire swapping, and suspension swapping between the two cars today, the TD had bilsteins and way better tires on it, so I went ahead and swapped everything back and forth between the two. Still have to do the front struts sometime.
                            Oh and found out the diesel has a bad intank fuel pump, so I'm going to have to replace that before I swap the gas tanks.
                            • iwantspeed
                              • 3164
                              looks like fun
                              Project
                              Parts for Sale
                              Feedback
                              YouTube Channel
