m21 swap underway
  • e30love
    • May 2007
    • 831
    #31
    Cool project.
    24v swapped
    • redbull 325is
      • 7471
      #32
      m21 starters are alot more beefy than m20 starters.. IIRC.
      Build Threads:
      • RedStar240
        • Mar 2007
        • 769
        #33
        looks tight.. good luck.
        Benji
        '90 M50 + M3 Tranny e30 - SOLD
        '99 528iT (M5 Rep bumper) - SOLD
        '03 ML350 - For Sale
        BIMMERLESS at the moment. :???:
        • rs4pro3
          • 5808
          #34
          Finished swapping suspension parts between the cars today, and started on swapping the engines.
          Fuel tank out of the diesel(e28 tanks are 100 times easier to drop then e30 tanks)
          And here is the old eta engine before I yank it out
          I plan to have the eta engine out tommorow, and then start on the wiring and pedal swap. MY goal is to have the car running by the weekend which should be perfectly doable unless I hit some large snag along the way
          85 325e 2.7 ITB'd stroker
          • PiercedE30
            • Apr 2005
            • 4220
            #35
            You going to put an intercooler on it?
            My 2.9L Build!
            • rs4pro3
              • 5808
              #36
              Ya later on I'm going to throw the intercooler on, I'm going to go ahead and make room for it but I still have to get piping etc.... before I stick it in.
              Update:
              M20 is out(Pics will be up in a bit)
              Ready to be pulled
              Parts starting to pile up
              Out she comes
              It's out
              Empty engine bay
              • Erik j
                • Jan 2008
                • 939
                #37
                That last picture looks more like water than a empty engine bay..... did you dump your engine into that bay?
                Tri color fabric for sale here!
                http://www.r3vlimited.com/board/showthread.php?t=105922
                • rs4pro3
                  • 5808
                  #38
                  Ok pics are working no, that was an old pic I shot one day on a drive, my file uploader was giving me trouble earlier but it's working now.
                  Got the pedal box in, gas tank out, and about 60% of the wiring done.
                  Torn apart interior
                  Nice new pedals
                  Diesel check control panel wired in
                  • VacMan
                    • Apr 2007
                    • 2405
                    #39
                    Nice work! I'm blown away by the fact that you're doing this by learning as you go. Can't wait to see some videos of you using that diesel torque to do a burnout for us. :D
                    Tim
                    • rs4pro3
                      • 5808
                      #40
                      well this is the 6th engine swap I've done, so it's no big deal.:pimp:
                      • golde30
                        • 11464
                        #41
                        i thought i was trippin at first, then i realized the red was a respray. i wanna see a big fat turbo on that sucker.
                        IG: @Baye30
                        • rs4pro3
                          • 5808
                          #42
                          More progress
                          Wiring the c101 plug in for the new engine
                          Diesel cluster in and all wired up
                          Hum 5-speed shift lever
                          Engine is in
                          I should have it all buttoned up tommorow, still have to install the driveshaft, exhuast, fuel tank, radiator, and put the interior back together.
                          • rs4pro3
                            • 5808
                            #43
                            Well she runs, fired right up on the first crank after bleeding the fuel system :woowoo:
                            The 5-speed is for sure what the diesel engine needed. I can now hear the turbo starting to spool about 2200 rpm's where as before with the auto you'd never hear it spool up. I don't really feel a big boost in power when the turbo kicks in, but I'm sure this engine needs everything adjusted. I still have to install all the new vacuum lines, and am going to pick up a boost gauge and make sure the waste gate is adjusted correctly. Right now just eyeballing the gas gauge and the odo, it appears to be getting around 30mpg :finger:
                            • rs4pro3
                              • 5808
                              #44
                              And here are the pics, I'm going to mount the intercooler later on.
                              Fabbed up temp cold air intake
                              Interior mostly back together
                              • RobertK
                                Kicked cancer's ASS.
                                • Jun 2005
                                • 5864
                                #45
                                I swear... one of these days I'm going to buy you a pressure washer and show you how to clean up your parts... (j/k)
                                Looking good.. Should make a great economic E28.
