Maybe in the Spring
  • Zyth01
    • 121
    Got bored and therefore my trunk paid the price.
    Before
    After (The battery protector tray went back where it belongs)
    Spare tire, 34lbs
    The Widowmaker Jack 4lbs
    Pad for under the spare tire 17lbs
    All the junk
    • Zyth01
      • 121
      Has anyone taken off the layer of sound deadening material that is adhered to the metal of the trunk?
      I heard that stuff is quite heavy but I don't know how to take it up.
      • Danny
        • 14216
        Dry Ice iirc
        • einstein57
          • Jun 2007
          • 10780
          Hundred degree weather and a platic putty knife to get it started. You can slowly start peeling it up in entire sections. Total weight is 45lbs iirc.
          www.gecoils.com
          • george graves
            • 19996
            Mineral spirits to clean up residual
            Originally posted by Matt-B
            • Zyth01
              • 121
              So I need to move? ;)
              I guess I'll go at it with a heat gun next time I'm feeling rambunctious.
              • Zyth01
                • 121
                After work I decided to try and patch up the rusty hole that has been working its way through the exhaust resonator for the past 25 years with some muffler bandage, I figure its worth $5 to try and make it flow better, but definitely not worth buying new exhaust parts since I'll eventually need a full turbo-back system anyway. My dad caught me trying to put the patch on and told me to step aside:
                Unfortunately he was only able to weld up the hole on the bottom, afterward we ran the car for a bit and it was still making noise like it had a leak, turns out an even larger hole is on top, and we can't get at it without taking the exhaust off. Since the motor is coming out this weekend I figured I could suffer a few more days of leaky exhaust.
                So, since I had the car already jacked up into the air and I had no idea how long the differential had gone without fresh fluids, I decided to check it out.
                Top bolt fill, bottom drain
                10mm Allen socket fits in both bolts, I believe the bolts are interchangeable as well
                Out with the old fluid
                In with the new fluid, with this handy pump it only takes 3 hours to pump the new fluid in
                The only measurement of the amount of fluid required for the 3 series differential is 3.59 pints. And they sell 75w90 here in quarts. So my backyard math declared that I need "Bout two" quarts of fluid to fill up the differential, luckily this style of differential can't be overfilled since the fill hole is exactly high enough that when its at the perfect amount it starts to spill out if you try to fill it past that. So at about 1 3/4 quarts (roughly 3.59 pints) I started to see some oil seeping back out.
                Once the bolts were back in place and the differential was all filled up, I gave the casing a well deserved bath. Too bad next time I go to work on it it'll be covered in grime already, but I digress.
                • Nicademus
                  • 2912
                  Great work man! Inspires me to do the same. How long did it actually take to fill it back up? A few minutes?
                  Well, posterity, you will never know what it cost us to preserve your freedom. I only hope that you will make a good use of it. If you do not, I shall repent in heaven that I ever took half the pains to preserve it.
                  ~ John Adams ~
                  • Zyth01
                    • 121
                    Yeah it only takes a few minutes, but the pump I had didn't have much distance in the actual pumping action so my arm got tired pretty quick :)
                    • Uber E30
                      • 1409
                      subscribed
                      -Alex
                      • alpinaclone
                        • 820
                        I'm glad to see that you are going through it and doing the little tedious things before you jump right in and start the good stuff.
                        Matt
                        • Zyth01
                          • 121
                          Hopefully I can start on some good stuff this weekend, but I'm having a hell of a time getting the correct intake, exhaust, and valve cover studs/bolts part numbers and I'd like to have them before I take the old head off.
                          • Spiff325iS
                            • Jun 2004
                            • 1263
                            Lookin' good man. I love these kind of restore/build threads. Moarr.
                            The Red Dragon V.5 1991 318iS / 2013 F800GT
                            "You gotta fix the nut behind the wheel before you fix the bolts on the car"
                            • Zyth01
                              • 121
                              FedEx man came today with a package for me.
                              Kind of dirty, kind of stock, but from a much better engine.
                              Comparison of the runners from the eta to the i
                              And after I cleaned it up a bit
                              Thanks again to Ray McCooney for the "i" manifold. It might not be quite as good as the 666, but couldn't beat the price/upgrade ratio.
                              Hopefully the engine/trans removal starts tomorrow, I'll be sure to take off the eta manifold and show the throttle body and runner differences :D
                              • E30_fiend
                                • Apr 2006
                                • 7348
                                Looks like everything is coming along nicely.
                                One question though, the Mobil 1 you put in the diff, did that have an LSD additive??
                                Taylor
