Indeed it does, the type I used was the 75w90 LS. If you ever own a GM vehicle with an LSD they used to offer an additive that you would put in the differential fluid, but they discontinued it so now they just tell you to use the Mobil 1 LS, since it already has it in it.
From the mobil1 website:
I'm not sure if the Redline gear oil that a lot of the guys on this forum are in to has the LSD additive included. But Mobil 1 has always been good to me and my cars so I stuck with what I know.
Mobil 1 Synthetic Gear Lube LS 75W-90 contains special friction modifiers designed for limited slip-type differentials. In most applications, the addition of special LS (limited slip) additives is not required. For axles requiring the highest level of limited-slip performance, OEM specific LS additives can be added to this fluid.
For more information, see the Mobil 1 Synthetic Gear Lube LS 75W-90 Product Data Sheet.
