JackBenny's 1991 318is Project
-Josh
Check out my build thread...
http://www.r3vlimited.com/board/showthread.php?t=131055
Need parts? Support the community!
http://www.gutenparts.com
http://www.blunttech.com -
The car looks great. But I think it would look way better with an M Tech II body kit. But that's just me.1990 Alpinweiss 325i - secret 500whp buildOriginally posted by audiquattrotbimmers b4 b*tches....remember that.
2000 Audi S4 B5 Laser Red
1990 Nissan 240sx - Drift Missile
2006 CBR600RR
So what's going on with the e21?
This car is looking perfect the way it is...Comment
M Tech II was considered. It's about 10 pages back or so. The issue I had with the M Tech II is that I like the front and the back but just don't like the door pods. That and the fact that the money I would have to spend to get a kit I could put to use getting the car back on the road.
The E21 has a new battery which has improved its startup. Aside from the hood unlatching on me yesterday as I had the 85mph speedo pegged, its doing great. It just isn't getting much attention due to the 318 requiring so much effort. It was fun driving it though and at the local bimmer club meeting last night, many ideas for improvement were thrown around. Once this build settles down, I'll start the E21 thread.-Josh
http://www.blunttech.comComment
Real excited to see this build completed so that we can see how good it turns out as well as see the beginning of the e21 build. Good luck, and keep the updates coming.
The E21 has a new battery which has improved its startup. Aside from the hood unlatching on me yesterday as I had the 85mph speedo pegged, its doing great. It just isn't getting much attention due to the 318 requiring so much effort. It was fun driving it though and at the local bimmer club meeting last night, many ideas for improvement were thrown around. Once this build settles down, I'll start the E21 thread.Comment
Just picked up some of that actually. Can't comment on adhesion, etc. until install but it would probably be great for Josh's application. Plenty firm to hold shape but soft enough to allow sufficient give.All might not approve, but if you want a bit of foam in there to make it a bit plusher, why not go with some foam type sound damping material? I have never used this stuff, but its 1/4th an inch thick and you can layer it up if you want it thicker. It will only help with the higher pitch sounds.
As far as closed/open cell and mold/mildew resistance. I wouldn't let it be a deciding factor in what you choose. Things have to get wet and stay wet for mold to grow.Comment
I've been spending a lot of time searching in the 24V forum looking at the harness threads. A big thanks to all who have been contributing their diagrams. I took the 318is diagram that's been floating around a bit and made some tweaks, specifically adding some notes from BeirBrenner's "Love your C101" thread. Attached here is my chart so far:
I still need to label the harness and double check all colors against the ETM. I will be placing the C101 plug on the engine harness for a cleaner harness.
Please check this diagram if you would be so kind. You stare at this stuff enough, you begin to miss simple mistakes. This community is very good at looking out for each other so I thought this might be a good place to post it.
Car is a 1991 318is with an OBD1 S52 engine harness.
Thanks a bunch guys.-Josh
Excel Sheet looks perfect, exact same as mine :)
-CamComment
-Josh
-Josh
The weekend is over buddy, where are the updates?
Be there or be square.....or round, or some sort of equallateral triangle.-DanComment
