JackBenny's 1991 318is Project
  • e30m3s54turbo
    • Jun 2010
    • 3290
    #751
    I like gauge panel & wheels.
    • UNHCLL
      • 8790
      #752
      Originally posted by jackbenny
      And that brings us to Ary's wing, which is going to need a lot of work. here you can see how far off the mounting holes are from the needed mounting holes.
      The plan right now is to drill out all of the inserts and epoxy the holes, then redrill them in the right locations and epoxy in studs (in metric instead of english :roll:) I can then bolt it to the trunk lid and finish shaping and sanding the wing.
      Sure is windy out there, Guess I better prepare the homestead.
      Without going through the entire thread, does your trunk already have OEM holes in it for a rear wing? iS perhaps? Those should serve as the true metrics.
      I was a bit confused by the above photos. You aren't using the mounting holes for the rear trunk trim as a reference for where the holes for the wing go, right?
      Below the radar...
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        #753
        ^I'm pretty sure he wasn't using the inner trunk trim to gauge the holes, I think the picture just confused you. It did the same to me.
        • jackbenny
          • 414
          #754
          I can see how that might be confusing. Is spoiler holes exist on the trunk lid and I increased the diameter to aid in adjustment. When I put it on the lid held on by just the center two bolts, nothing lined up. I centered the wing and then marked where the trunk lid holes were on the wing. Those are the red circles you see. Stunned by what I saw I measured the original inserts that came with the wing and they weren't even symmetric. The red marks do match the service manual measurements.
          I should have held out for an original.
          -Josh
          Check out my build thread...
          http://www.r3vlimited.com/board/showthread.php?t=131055
          Need parts? Support the community!
          http://www.gutenparts.com
          http://www.blunttech.com
          • Massimo
            • Jan 2008
            • 3207
            #755
            Wow can't believe this is 3 years old now. I did not know about those MemoryFab wheels. Thanks.
            I really can't wait to see this car done now.
            • LJ851
              • 7919
              #756
              As you now know, 99% of aftermarket fiberglass is absolute sh*t. You would think that making a decent mold requires a blood sacrifice and your first born child.
              Fantastic work by the way....
              Lorin
              The M30 is God's engine.
              • mtlbloodshot
                • Jul 2011
                • 761
                #757
                How did you get your Z3M DIFF to work?You changed the output shafts?
                MY BUILD THREAD
                http://www.r3vlimited.com/board/showthread.php?t=235231
                INSTAGRAM : @luchcolaneri
                • ///M42 sport
                  • 3952
                  #758
                  I dont get it either. How hard is it to make a decent replica?
                  • jackbenny
                    • 414
                    #759
                    Yep, popped the output shafts on the original diff (used a long screwdriver between the output flange and the case) and put them on the z3m diff. I think there is a diy in the 24v forum.
                    Annoyance, I haz it. Ive made progress with it but ran out of sandpaper. I also had a fairly significant set back on the car but that post will have to wait. Off with the wife on date night to see dark night rises.
                    -Josh
                    • jackbenny
                      • 414
                      #760
                      the setback previously referred to
                      yeah, so i've been busy...
                      but progress has been made though it's pretty pathetic. First things first. Who wants to guess what happened in this picture?
                      Details at the end of the post.
                      A great deal of work has been spent working on the Mtech I replica wing. I will just say that I am disappointed in the quality of the wing and leave it at that. I think the pictures will do the majority of the talking. I didn't get any pictures of it but I taped the decklid and then bolted the wing down in the correct position. The gaps were atrocious so I filled them with the filler. From there, I used lots of water to soak the tape and some floss to separate the tape from the deck lid. The result was a wing perfectly contoured to the trunk.
                      The filler isn't terrible thick either but it made a big difference in appearance. I decided to work on the back of the wing and get it flat. I used some dura block sanding tools and sandpaper combined with some Rage Extreme filler.
                      After sanding, things started looking better.
                      Fitment with the insert still wasn't satisfactory.
                      You might notice that the primer looks to be flaking off in spots. After I picked at it I came to find out that the primer did not stick to the top surface at all. That was a lot of work that came off in sad green ribbons. So I started over.
                      Identifying the known low spots
                      I needed a sanding form that would provide the correct curvature for the top of the wing. After digging through the garage and house, I found a pet furniture cleaner that had just the right curvature. Worked like a charm.
                      I was forced to use markers to determine the high and low spots as I didn't have any guide coat.
                      I elected to use the same tape trick to get the insert edge exact. I did take pictures of this process.
                      Filler was applied bridging the gap and then the tape removed carefully after the filler started to kick.
                      The result was a pretty consistent gap that will need some minor cleanup.
                      As the sanding continued, the top edge of the wing started to thin out and I discovered voids...many many voids. I filled them all with epoxy, resanded the entire wing with 80 grit and reapplied the primer. It should stick now. And then the process will repeat. <sigh>
                      For those who guessed that my passenger door hinge pin bushing sheared, you got it right. Unfortunately, I got some damage combined with it too.
                      I'm beginning to think this car hates me. I can't tell you how sickening the feeling was to push the door closed and have it bounce back because the back edge is down an inch or two. Ugh. Looks like Blunttech will be getting another order. I just want the exterior finished at this point.
                      Hopefully another update soon.
                      -Josh
                      • mtlbloodshot
                        • Jul 2011
                        • 761
                        #761
                        Good luck on completing that wing. Its gonna look great. Sorry to hear the news about the door hinge, but hey its all part of the love/hate thing everyone has with their e30. You'll get over it
                        MY BUILD THREAD
                        • TrentW
                          • 2815
                          #762
                          That's a whole lotta work on the spoiler--but as already stated, it will look great in the end. I stumbled upon my OE one on craigslist one day from someone who really had no idea what it was worth, and I considered selling it for a profit, but then came to my senses.
                          You've got persistence and patience Josh.
                          • Massimo
                            • Jan 2008
                            • 3207
                            #763
                            You are a patience man.
                            • ///M42 sport
                              • 3952
                              #764
                              god damn thats alot of work on that spoiler
                              • Mtriple
                                • 3139
                                #765
                                Keep it up! I feel somewhat ashamed to see you put all this work into that spoiler and I'm contemplating taking mine off my car.
                                Originally posted by Simon S
