Help 01' Solara Won't Charge
  • 88Sedan
    • Apr 2023
    • 275
    I am having a charging problem with my 5sfe 2001 Solara that started when the battery was low and the car wouldn't start one day. I checked the battery date and it was almost 10 years old, so I went to the store to get a replacement battery. Upon putting the new battery in, the idle was too low at around 450-500RPM and the engine was running terribly. I put a voltmeter on the battery terminals and the car wasn't charging. That explains the low battery, but I noticed that if I kept the RPMs up it would keep the system above battery voltage but anywhere near idle speed(<2000rpm) and the battery would begin discharging.
    Thinking it had to be the alternator since this problem started suddenly, I ordered a new one. Well the new alternator is acting the same way the old alternator was. Part is correct, pulley size is correct and belt is not slipping. This is where the electrical diagnosis started. Here are the conditions:
    Idle (~600RPM): No accessories or lights on, voltage never goes above battery voltage 12.5V, and system voltage quickly decreases to below battery voltage as alternator is not charging at this RPM at all
    1000 RPM (Well above normal idle speed): No accessories/lights on, same as above just not quite as bad (aka still discharging just less quickly)
    2000RPM: With no accessories or lights car makes 14.4V, with only lights on 12.7V (notice the huge drop from just headlights), with lights and fan on high 12.7V
    Every single fuse has been visually checked and continuity checked, exterior and interior, yes every single one so please don't suggest this. I even cleaned the fuse blades. Yes the fusible link was checked as well.
    Every single engine ground point was removed and wire brushed including the fasteners then cleaned and reinstalled. I checked that the control terminals on the alternator plug are getting correct voltage for both constant 12V pin and switched 12V pin. I also checked that from the alternator output terminal to the (+) battery terminal were getting very close to the same voltage aka voltage drop test and did the same between the alternator case and the battery (-) terminal.
    Visual inspection of the entire charging circuit was done and everything looked good, various checks of continuity of grounds were good. I even added new grounds to the alternator case to rule out that the mount wasn't grounding correctly. The harness at and around the ignition switch all looked normal, car still starts right up just won't charge.
    I read that throttle body issues can cause weird problems including charging issues with Toyotas, and since I was having an abnormally low idle I decided to pay some attention to this area. I removed the throttle body and then the IACV, both of which I have cleaned before in somewhat recent time. Nothing crazy here, except that the IACV resistance readings were way out of spec. So that is probably what's been causing the idle issues. Mine wasn't even dirty but I am pretty confident it has failed because the resistance readings were crazy far from spec. I am waiting on the new IACV to be delivered, however I am not convinced that this has anything to do with the charging issues I am having.
    The voltage levels during different conditions I posted above show me that even if my idle speed picks up about 150RPMs to where its supposed to be, that it won't affect the charging system. The battery symbol on the dash lights up during key on (before start) like it is supposed to but while the car is running it doesn't turn on even when the running voltage is 12.5V. The IACV short circuiting is the only idea I have but that is such a longshot and I don't even know if that's possible or if it could even cause what is happening.
    I did loaded voltage drop tests on both sides of the circuit and it passed with very good results.
    I don't have an oscilloscope to test the wave form voltage to the alternator control plug which is the only test left that I can think of. I am also going to pull all non essential fuses to rule any short circuits out.
    Are there any other tests I can perform before swallowing my pride and going to a shop? Is the new alternator bad (or specifically regulator)? The annoying thing is I purchased the new alternator from RockAuto and I assume I would need some form of shop proof that the new one has a bad regulator. To be honest I am not even convinced at this point that this is what's going on, because the old alternator was doing the exact same thing (not charging at idle or close to idle, and charging at 2000+ but not enough with lights or accessories on). Open to any ideas that are not things I have already done, as I did each test that I mentioned multiple times.
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5604
    When you disconnect the battery on those old Toyotas the idle parameters are lost and you need to idle the car for it to relearn and begin to idle correctly
    It wasn't charging because the engine speed was too low.
    You're good dawg
    • 88Sedan
      • Apr 2023
      • 275
      No it doesn't charge even at 2000 rpm with lights on or with lights and blower. I'm not that silly.
      • roguetoaster
        Biggus Tippus
        • 7830
        I could certainly see a TPS causing an issue, either too low, or too high throttle position causing no charge. Unplug the TPS, if it'll run without it and try again. I would personally think that actual engine speed would predicate charging on/off, but perhaps Toyota cares about load instead of speed.
        • 88Sedan
          • Apr 2023
          • 275
          Ok that's worth checking thanks. Toyota does some weird stuff with their charging circuits. Some people have had throttle body issues cause charging problems.
          • 88Sedan
            • Apr 2023
            • 275
            Just to follow up for those curious, there were 2 things going on causing the charging issues. My idle air control valve had degraded just enough to lower the idle speed below charging threshold which is what slowly killed the battery. The valve wasn't dirty or fully-failed, but had weakened to the point of no longer working correctly. What made this a tough diagnosis is usually they fail entirely creating a no idle or high idle condition.
            I could find ZERO free resources on how to test the California version of this valve... and yup it works entirely differently (electronically) than the 49 state version. SMH. 49 state version simply has some resistance you can measure, but the CA version is wildly different than the other and I couldn't find any testing information. I only figured out the valve was problematic because...
            When I installed a new alternator after replacing the battery it wasn't charging at idle, but would charge off-idle...for a few minutes anyway. As soon as the engine was allowed to warm up it wouldn't charge anymore. Revving the engine would let the alternator charge while cold, but it wouldn't charge at all once the engine ran for ~6 minutes. Even at 2k rpm. This immediately made me suspicious of the new alternator.
            Now with a new idle control valve installed, I wanted to rule out the alternator so I reinstalled the original. Charging just worked after all that hassle.
            PSA to not throw out your old parts unless you're sure it's junk! And I confess I jumped the gun assuming it was the alternator when it wasn't charging, but I got lucky the new one was defective and should be returned easily--I even shot video in case they hassle me about the return.
