BRoked oil pan
  • SLUCK
    • Nov 2007
    • 344
    BRoked oil pan
    So i shatered my oil pan yesterday. i have an 87 325e, any 6 cylinder oil pan will fit right? (besides an ix). Any info on switching an oil pan out would be greatly appreciated.
  • e30-RTN
    • Jan 2008
    • 461
    Google e30 oil pan removal and you can find quite a nice write up.
    I have also heard people say that you can unbolt the motor mounts and jack the engine up to get the extra clearance that you need to get the oil pump out.
    Simplisticly you would:
    Remove the ~15-20 10mm bolts around the oilpan
    Remove the ground wire
    Remove the oil level sending unit
    Raise the engine
    Remove the 13mm bolts holding the oil pump in. Let it drop into the pan
    Remove the pan
    Reinstall new pan
    I recommend using Indian Head Gasket Schelac
    Hope that helps.
    Enter the Internet!
    • learningcurve86
      • May 2008
      • 715
      i have the whole assembly from my 87 is.. $90 shipped to your door :) (oil pan, dip stick, pump, ect)
      Greg
      • scabzzzz
        Estado de mierda de encargo
        • 6871
        Step 1: Take off pan
        Step 2: Install new pan
        Step 3: Smoke bowl
        Step 4: Drink beer
        • shiboujin
          • Feb 2006
          • 2791
          • Desaevious
            • Aug 2007
            • 3810
            This just happened to me two weeks ago, pure carnage. As long as you didn't do any other damage you'll just need a new gasket. Make sure the drain plug on your new pan isn't stripped either.
            Good luck man!
            SC*AR (Schwarz Army)
            • bikerbill2021
              • Mar 2008
              • 933
              when deano told me you kept driving it like that, i was gonna drive to honeoye yesterday and smack you upside the head haha
              • SLUCK
                • Nov 2007
                • 344
                Thanks for the tips fellow R3Vers. I actually found a local guy that had a parts car. He just let me have the oil pan fo free. it was actually really easy to get off with the whole front of the car already chopped.
                Downz- haha just for the love of god dont take County road 37. unless its with the jetta, that thing needs to die sometime.
                • Tree18is
                  • Mar 2004
                  • 2703
                  WATCH your finger/hands over the edge, put car on stands. drop the subframe bolts A LITTLE and buy a ratchet wrench. I did it when I was like 15. real easy, just dont cut your hands.
                  • bikerbill2021
                    • Mar 2008
                    • 933
                    haha oh piss off, that thing will never die, and if it did, youd be the first to weep :finger:
                    sweet drunk title btw haha
