physics question
  • b*saint
    • 3794
    physics question
    Its probably pretty basic but for some reason I cannot remember this - On a rotating axis, if the axle is a constant speed, what is the speed relation, in rpm, 3" from the center as to 6" from the center? Twice as slow / twice as fast / or the same speed? I think its slower the further away from the center you go. If I remember right, this is the old way machine tools controlled their speed.
    Ma che cazzo state dicendo? :|
  • Wh33lhop
    • 11705
    Linear speed is doubled, rotational speed is the same.
    paint sucks
    • snitzer
      • Jul 2008
      • 137
      http://www.engineersedge.com/
      • decay
        • 5637
        the plane won't take off.
        past:
        1989 325is (learner shitbox)
        1986 325e (turbo dorito)
        1991 318ic (5-lug ITB)
        1985 323i baur
        current:
        • Bimmerman325i
          • 6854
          w=v/r => v=rw
          if r1=3, and r2=2*r1=6, v1=3*w, v2=6*w
          v2=2*v1, w is constant.
          In words, the farther you go from the center of the axis with a constant rotational speed, the higher your linear speed will be.
          2017 Chevrolet SS, 6MT
          95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
          98 M3/4/5 (stock)
          • briansjacobs
            • 1278
            C
            Brian Jacobs
            • reelizmpro
              • 9543
              It's been a while but a big diameter wheel will have less revolutions than a smaller wheel. We see this on our cars when we run wheels with smaller overall diameter than what came stock so our speedos read higher than we are actually traveling. However, if you're talking about 1 wheel, it will have the same RPM 6" from center that it does 3" from center since it's a solid wheel.
              88 M3 - LACHSSILBER
              89 M3 - ALPINEWEISS II
              • b*saint
                • 3794
                ok so no matter what size pulley I use, it will always be spinning at the driving rpm anywhere on the pulley. Its the linear speed that varies. Thus a 6" pulley is spinning slower than the 3" driving pulley because its coupled with a belt moving literally linearly.
                • mrsleeve
                  • Mar 2005
                  • 16386
                  this
                  Originally posted by Fusion
                  William Pitt-
                  • SpoolnDaapex
                    • Jan 2010
                    • 150
                    This probably doesn't help much but the only thing i know is that people change the pulley sizes on supercharged cars to make more boost.
                    M42: Because 110 feels like 140 :finger:
                    • mrsleeve
                      • Mar 2005
                      • 16386
                      similar principal, smaller pulley = faster rotor speeds (rotational speed) = more boost this is more to do with gear ratios than axle speeds
                      But when you have something that is attached to the same axle the further away you get from the center of the axle the faster the liner speed needs to be to make 1 Revolution at the same rate as the center of the axle.
                      William Pitt-
                      • Erik
                        • Oct 2005
                        • 5370
                        Hahahaha YES!
                        -Erik
                        Originally posted by 87e30
                        • Jand3rson
                          • 37587
                          • Wh33lhop
                            • 11705
                            Yes. The belt will be moving at the same linear speed with either pulley, and a 6" pulley would turn over at half the speed of a 3" pulley for any given linear belt speed.
                            paint sucks
                            • fryerfighter94
                              • Jan 2010
                              • 794
                              Originally posted by teamdynasty43
                              Aye listen here ph fucking dick cheese mother fucker ...go back to touching your self or your fucking boyfriend because you're just some dumb mother fucker that has no fucking life than other to ridicule others because you have no fuckin life and low self esteem so you try to make your self feel better so you act all big!!!! Sooooo get the fuck out of here and shut your stupid little Whore mouth the fuck up and just leave!
