Solar roads!
  • ForcedFirebird
    • Feb 2007
    • 8300
    #61
    Originally posted by Raxe
    Yes I'm sure, you stated torque is equal to rpm. Not sure why you're justifying it with the formula for calculating hp?
    Because you said the MYT engine would have no torque, but at a high enough RPM, torque is present. The MYT engine makes an amazing amount of HP, therefore at a high RPM, it would also have torque.
    john@m20guru.com
    Links:
    • mrsleeve
      • Mar 2005
      • 16389
      #62
      Which is nearly useless in a car or truck engine. In a airplane or something that runs at peak power production to provide power to hydro pumps, or gen sets, is about the only place they would work.
      TQ at the bottom is hard to give up once you have had it. I DD a duramax with 590ft/lbs at 1600ish RPM stock. I get in the little womans Tahoe with a 350 that makes like 300 ft/lbs and I am like WTF GO where the fuck is the power?????????
      I know you have to keep e30's and similar speced engines wound up and drive them as such. You cant expect the general public to buy into something that you have to run wide open just to get to move thanks to the lack of tq.
      Originally posted by Fusion
      William Pitt-
      • z31maniac
        • 17566
        #63
        It sounds like you don't fully nderstwnd the difference between tq and hp.
        www.gutenparts.com
        • mrsleeve
          • Mar 2005
          • 16389
          #64
          it sounds like you don't fully nderstwnd the difference between tq and hp.
          me ??????????????????
          William Pitt-
          • z31maniac
            • 17566
            #65
            No boy genius ahead of you.
            "At a high enough RPM torque is present"
            lol
            www.gutenparts.com
            • mrsleeve
              • Mar 2005
              • 16389
              #66
              lol
              hahahahahahahahahahahahaha
              I assumed, just wanted to be sure lol. and that comment is just why a MYT would not work even if they tried it. Why do you think the Wankel is has been a dismal failure and only HAS 1 production manufacturer, even arctic cat abandoned them way back in the 70's
              William Pitt-
              • Fusion
                • Nov 2009
                • 3659
                #67
                Question is: if you were to almost get in a mean crash, but had to abruptly drift your way out of the bad situation, would it work?
                Someone please contact the bearded guy, can the solar panel be drifted?!?!
                • mrsleeve
                  • Mar 2005
                  • 16389
                  #68
                  I am really starting to like you more and more
                  William Pitt-
                  • z31maniac
                    • 17566
                    #69
                    To be fair the linear tq "curve" of a wankel is desireable in certain applications, it's mainly been a failure because it has poor emmissions, poor fuel economy, and poor HP given it's size/fuel usage.
                    I fall into the 1.3L rotaries are actually 2.6L engines.
                    www.gutenparts.com
                    • Danny
                      • 14216
                      #70
                      • u3b3rg33k
                        • Jan 2010
                        • 2452
                        #71
                        Originally posted by thornado327i
                        There is one more issue:
                        The energy needs to be stored before it gets used. ...
                        For all these green energy stuff nobody thinks of costs of disposal of used stuff, and the only way for it to be cost effective and non-polluting energy would be to direct it straight to the mains bypassing the storage.
                        In case you're still wondering, most multi kW solar systems are grid tie only.
                        I guess you forgot about the airplane market? They're more popular where lift:weight is more important.
                        Ich gehöre nicht zur Baader-Meinhof Gruppe
                        Originally posted by Top Gear
                        Just imagine waking up and remembering you're Mexican.
                        Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
                        • mrsleeve
                          • Mar 2005
                          • 16389
                          #72
                          Wankels were used in anything more than ultra lights????? I was unaware or are you getting rotary engines=wankels confused with Radial engines. Not the same thing. Most HiPo small aircraft engines are turbo flat 6's or even 4's. Any bigger than that they are radial or turbine. A big wankel would be hard to keep air cooled, this is why the artic cat snowmobile wankel engines failed all the time in the 70's and early 80's over heating
                          And I did mention where a MYT may work as a Plane power plant due to the long runs at High RPM at peek power production.
                          and Danny :rofl:
                          William Pitt-
                          • u3b3rg33k
                            • Jan 2010
                            • 2452
                            #73
                            I'm most definitely not confusing wankel with radial engines.
                            As for MYT, I'm intrigued by it.
                            • Wiglaf
                              • Jan 2007
                              • 1513
                              #74
                              not to burst your mostly accurate bubble, but one of the wankel's biggest advantages is being very small/light for the power it puts out.
                              Originally posted by u3b3rg33k
                              If you ever sell that car, tell me first. I want to be the first to not be able to afford it.
                              • Raxe
                                • 5346
                                #75
                                I think you're a little confused about the difference between torque and HP still.. if you want some quick examples of high HP/RPM and low torque applications look at motorcycles and Formula 1 cars making 750hp and 200 lb-ft at 19,000rpm.
                                But even regardless of that, the MYT currently makes no horsepower because a working prototype of it has still never been built. Dreams are fine and dandy on paper but won't get you very far.
