Brabus 190E 3.6S - Bahn Stormer
  • dude8383
    • Jan 2005
    • 10387
    Came across this gem while I was reading my mag...I had no idea this existed!
    The Brabus 5.0 liter V8-powered 190E of 1984 was spectacular but expensive and impractical for most customers. So the M103 straight-six that debuted with the W124 in 1985 was a godsend.
    As its reply to BMW’s 323i, Mercedes dropped the 2.6-liter version of this engine into the 190E, and the power race was on. Where AMG was more tentative, producing 3.2- and then 3.4-liter versions of this tough new straight-six, Brabus’ development chief Uli Gauffres went straight for the jugular with 3.6.
    With 268 hp and 269 lb-ft of torque, the 12-valve 3.6S rocketed to 62 mph in 6.3 seconds and on to 162 mph with the shorter sprint rear diff or a 177-mph top speed with the taller equivalent. The extra 25 hp and 18 lb-ft that came with the M104 24-valve based 3.6S version in 1990 made little difference against the stopwatch, and the 12-valve M103 was reckoned to be more robust in the long term.
    I remember driving the original red 3.6S back in 1988. I had already tested the 190E 2.5-16, and while this factory homologation special was a track demon, it lacked low-end torque in normal road conditions.
    In comparison, the six-pot Brabus 190E 3.6S was a revelation. The combination of a lusty, high-revving six-cylinder in a relatively light car was an intoxicating mixture. It was super smooth with plenty of grunt down low, and being blueprinted and balanced, it revved to the skies. This car just wanted to go all the time, so even though you could trickle through town effortlessly in a high gear, your enthusiast brain wiring meant it really was hard to drive slow.
    Low weight and a well-sorted chassis also meant agility and sharp handling, while strong torque and a limited-slip differential also provided loads of fun for drift junkies. In an age when compact cars really were compact, this was one very rapid and entertaining cross-country or autobahn stormer.
    This one is a better-than-new, one-of-a-kind Brabus 190E 3.6S replica that was slowly built up in 2008, and I’m having vivid flashbacks to the day I drove the original.. This brand-new car belongs to Sven Gramm, Brabus’ effusive PR manager, who built it from scratch as his fun car. It’s a dead ringer for the 1988 demo car, right down to the identification stickers on the under-bonnet slam panel. One subtle touch from the original car is the front grille, welded to the hood and color-coded red so that it all looks one-piece. The egg crate part of the grille, wiper arms, door handles, boot trim, and rear badges are all painted Mercedes 040 gloss black.
    This is one of my favorite Brabus cars of all time, Gramm says. It’s small and light, and has no electronics to interfere with the driving experience. It is effectively a 190E Clubsport, and is even faster and more hardcore than the factory 2.5-16 Evo 2.
    A good donor car is paramount for such a project, and Gramm was lucky enough to find a 190E 2.6 equipped with a five-speed manual locally, owned by an elderly man since it was new. Immaculate inside and out, this car had been religiously serviced at the supplying Mercedes dealer, and had covered 175,000 accident-free kilometers (about 109,000 miles). The original owner had obviously intended to keep the car a while as he had specified uncommon options like the 70-liter long-range fuel tank and heavy-duty battery.
    Gramm’s search for rare Brabus 3.6S parts began in earnest in January 2008, and he called in favors from friends both inside and outside of Brabus. Rummaging around Brabus’ spare parts warehouse coughed up the period front spoiler, alloy wheels, brakes, and some other parts. There were no rear spoilers, but we found the original mold and my colleague in the design department made one up for me by hand, Gramm says. I had to buy him dinnerbut it was worth it.
    While the original Brabus suspension kit was in stock, things had moved on in 19 years. Gramm spoke to his contacts at Eibach and Bilstein, who provided more up-to-date solutions. The new springs and dampers drop ride height by 40mm from standard, over 16-inch Brabus Monoblock I alloy wheels with Yokohama 048 225/45 trackday rubber fitted to them.
    The tires are available in soft, medium and medium-hard compounds, Gramm explains. The first set were soft and their grip was fantastic, but I got through them in just 2,500 miles. Now I have medium-hards.
    To make sure the body stays rigid under the onslaught of this grippy, low profile rubber, and also as a safety measure, Gramm fitted a Weichers rear rollcage and rear suspension tower brace. The big brakes behind the front wheels use 286mm vented discs and four-pot calipers with fast road pads, and stop the car very effectively from autobahn speeds.
    Shedding excess weight was a priority, so the rear seat was removed and the fronts replaced with lightweight Recaro Spa Kevlar seats. A Brabus Type II steering wheel provides good grip, and four-point race harnesses and a fire extinguisher system complete the safety equipment.
    The speedo was recalibrated to read to 300km/h, and the center console now houses a battery of oil temperature gauges for the engine, gearbox, and rear differential. The car has an oil cooler for each of these components, the rear differential cooler being housed between the rear spoiler and the bootlid.
    The 3.6-liter engine was another challenge altogether. Built individually for each 3.6S, this powerplant always started life as a new or slightly used 300E unit. When Gramm finally found one, the block and cylinder head ended up in the Brabus engine shop, where each was stripped and checked for any problems before work began.
    The 3.6S’s unique 3,590cc capacity comes from a bore and stroke of 92.2x90.0mm, making the engine slightly over-square. A new steel billet crank is mated to lightened and balanced connecting rods and bespoke KS pistons. Knowing that he would only do perhaps 3,000 miles a year, Gramm opted for the largest oversized pistons to get the maximum displacement.
    A local retired mechanic polished the connecting rods so they are not only lighter and perfectly balanced, they also look amazing. The cylinder head was gas-flowed, polished and given bigger valves, three-angle valve seats, and a Brabus high-lift camshaft. Compression ratio is 10.5:1. The air intake manifold was internally polished and eased to increase ram air, while on the exhaust side, a set of tubular headers and a stainless steel Brabus sport exhaust with twin 76mm outlets dramatically reduce back-pressure.
    The original 3.6S did not need a catalytic converter; however, Gramm elected to have a pair of 100-cell metal sport cats installed so he can drive the car into urban areas that require the mandatory green sticker.
    The positive effects that low weight and good torque from a large-displacement normally aspirated motor were starkly apparent as Uli Gauffres, in Gramm’s car, and me in a W211-based E V12, ran in tandem on the autobahn. As we accelerated, the 2,900-pound 190E 3.6S immediately pulled away while the turbos on the 4,500-pound E V12 were still spooling up. It was a few seconds before we blew by the older Brabus, but it did prove a point.
    And Gramm is clearly enjoying his car. But only in nice weather, he says.
    Specs
    Brabus 190E 3.6
    Layout
    Longitudinal front engine, rear-wheel drive
    Engine
    3.6-liter I6, dohc, 24-valve. Steel billet crankshaft, custom KS pistons, polished connecting rods, gas-flowed cylinder head was gas-flowed, bigger valves, three-angle valve seats, Brabus high-lift camshaft, polished intake manifold, tubular headers, Brabus sport exhaust
    Transmission
    Five-speed manual
    Suspension
    Eibach springs with Bilstein dampers, rear shock tower brace
    Brakes
    Four-piston calipers with 286mm rotors
    Wheels and tires
    Brabus Monoblock I, 8x16
    Yokohama 048, 225/45
    Exterior
    Brabus front and rear spoilers
    Interior
    Brabus Type II steering wheel, Recaro Spa Kevlar seats, four-point harnesses, Weichers rear roll cage
  • scabzzzz
    Estado de mierda de encargo
    • 6871
    Love that car. Its what made me want a W124 to begin wtih.
    • 10Toes
      Me Father Was A Tree
      • Jan 2008
      • 61222
      Cool car but I find AN lines with fake AN end hose clamps to be ricey.
      • dude8383
        • Jan 2005
        • 10387
        If only 5spd's were more readily available here I'd rock one!
        Meh, I don't mind it so much, it completes the look. At least they're not chrome!
        • slammin.e28
          שמע ישראל
          • 12054
          There was a nice 16v 190 5sp at an auto-x late last Summer. It did very well!
          I really like the w201.
          • IminDiegoTriick
            • Oct 2009
            • 1564
            fap fap fap fap fap fap
            Fast life fuck slow..Low life for life
            Let the mix flow..Let the night flow
            I'm so gone ✗ ♥ O
            • E30AWDAZ
              • 399
              I love the rear on these 190e's looks so classy
              This one is beyond epic for sure
              • equate975
                • Jun 2004
                • 3382
                Love that car. Its what made me want a W201 to begin wtih.
                fixed
                Rollin' with a Geistkuchen
                • mikeedler
                  • 6707
                  a good friend of mine had one of them in black, had no idea what he even had, thought it was just an old benz with an oil leak he wanted me to fix. I saw the motor and started googled it right away. his really wasnt that fast though, the motor was pretty beat I guess. the e30 is still a way better car!
                  • Fusion
                    • Nov 2009
                    • 3659
                    Some of ya'lls are mixing the types
                    W201 = 190 (pre-C-class), BMW 3 size
                    W124 = E-Class, bigger brother, BMW 5 size
                    The engine is from a W124 but placed in a W201.
                    I own a straight six C280 and the engines are just as durable and fun and easy to work on as the BMW bix sixes. The Brabus 190 3.6 is a great car, but rare and expensive. 24V swaps in the 190 are also possible, but aftermarket parts scarce compared to E30s.
                    • dude8383
                      • Jan 2005
                      • 10387
                      Pretty cool bit of info there. If I were to do this swap, I'd do the 12v'er.
                      • equate975
                        • Jun 2004
                        • 3382
                        I saw that edit.
                        • slammin.e28
                          שמע ישראל
                          • 12054
                          Originally posted by equate975
                          I saw that edit.
                          • Fusion
                            • Nov 2009
                            • 3659
                            I personally don't believe the 12 valvers are more robust. The 24v had better fuel injection/ECUs and ran a bit quieter with less shake.
                            24v's are also pretty easy to turbo/supercharge and can take a lot of shit from what I've read.
                            I should mention the ASD diffs, which can be changed from about 25 to 100% diff lock with the flip of a DIY hydraulic switch.
                            (not stock, taken from E's and C's)
                            • dude8383
                              • Jan 2005
                              • 10387
                              :eeek: o rly
                              damn, i might just have to look around for one of these. they're pretty cheap around here. what kinda trannies do they use for the 5spds?
