House flooded
  • Ray Smoodiver
    • Jun 2004
    • 8809
    House flooded
    Some major rain this afternoon saw the lower level of my house flood. I should have skipped after work drinks!
    The wet / mud patches are totally random and there doesn't seem to be a single source of water.
    What tips / tricks can r3v recommend to help me clean this sorry state of affairs? Bear in mind it's 10pm, I've had c. 6 beers and plan on switching to gin in about 5 seconds time.
    Iain has sent me the awesome flood cleanup guide, but anything else is mucho appreciated.
  • mrsleeve
    • Mar 2005
    • 16387
    Shop vac and a dehumidifiers is about all you can do.
    Once you get the bulk of the water vac'd up, get your self a roll away dumpster and start throwing shit away
    Originally posted by Fusion
    William Pitt-
    • george graves
      • 20003
      Originally posted by Matt-B
      • Jalves619
        • 596
        More alcohol is definitely the correct answer. Deal with it, along with the hangover tomorrow.
        Edit: Actually I'm voting for GG's solution over my own.
        • z31maniac
          • 17566
          Like sleeve said, get the water out NOW.
          Or the drywall will start soaking it up and molding/mildewing like crazy and then you've really got a nasty problem on your hands.
          I like GG's solution.
          www.gutenparts.com
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            Get a bunch of those moisture packets out of new shoes from China and place them about your home.
            But serious, that sucks, best of luck with it.
            • mitch500
              • Jan 2006
              • 1092
              cut drywall 2 feet up wall. remove drywall and remove insulation.....
              put in new insulation and re-drywall....
              your pretty much fucked. oh and if you have carpet.... get rid of it because the underlay has probably soaked up all kinds of shit...
              1988 e30 alpine white vert 5speed
              1987 e30 325 eta
              1983 e28 533
              2001 x5 4.4l
              1997 e36 M3 Alpine white 5speed
              1991 Jeep XJ I6 4.0
              • Todd Black 88
                • Oct 2007
                • 3449
                In all truth, this iswhat you will probably end up doing. The paper on the drywall WILL grow mold if its not completely dried.
                But GG way looks sooooooooo much better.
                Originally posted by codyep3
                I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                2001 silver/Blk 325 cabby. SOLD
                2002 325xit Sil/blk. SOLD
                2010 F650gs twin
                • Kershaw
                  • 11822
                  i vote for georges solution.
                  i am also currently turning my hose on inside my house. i am hoping for george's solution too.
                  AWD > RWD
                  • whterice
                    • Jan 2009
                    • 258
                    how long has the water been sitting? how much water?
                    If it has been sitting there for longer then 48 hours turns to "grey" water which is considered sewage. Thus everything has to be tossed. If water is under 2 inches of water cut drywall out at 2 feet over 2 inches cut out at 4 feet.
                    It sounds like you just have seepage going on which would be considered "fresh" water. If it came from the drain then it would be a sewage backup which underlay and carpet have to be tossed. With the proper vac your carpet and underlay can be saved with in the 48 hr mark. If you have a gauge to tell you the humidity level your goal will be to get it too 60% the first day and will be considered dry at 40%.
                    Best thing to do is suck out the water with a vac the best you can and get air movement going in a circular pattern and get a dehumidifier going as soon as possible.
                    • ck_taft325is
                      • Sep 2007
                      • 6880
                      2'-4' up the walls cut out is your only real solution. Let the studs dry completely. I'd put fans on 'em if you got them handy.
                      I suggest 4' up the walls as it's much easier to place 4'x8' sheets of drywall on the walls and then mud accordingly.
                      Need a part? PM me.
                      • whterice
                        • Jan 2009
                        • 258
                        He may have to replace the sil plates(bottom 2x4) if it is not pre treated wood or does not have a vapor barrier between the concrete and wood.
                        And why would he replace 2' of drywall if not needed he will just double he rebuild cost. Measure from 24.5" from the bare ground when cutting drywall to allow for .5" gap at the bottom so drywall is not touching the concrete
                        • ck_taft325is
                          • Sep 2007
                          • 6880
                          Ah, he's on slab then?
                          You can do 24.5" high but, depending on long the water has sat at 10" high it'll be up into the rock quite a ways.
                          Need a part? PM me.
                          • whterice
                            • Jan 2009
                            • 258
                            He says the lower level of his house so I assume basement which would be concrete floor....NO???
                            If you read my first post you will see I said if it is higher then 2" then he will have to cut out at 4'
                            • ck_taft325is
                              • Sep 2007
                              • 6880
                              Wow dude, slow your roll. I'm not questioning anything you said and frankly don't give a fuck. So, calm down. I suggested something, you got all uppity, it's cool. Let it go.
                              Need a part? PM me.
