1989 Hino SG 193 Class A?
  • TS323
    • 359
    i was curious if anyone can give me some info about different class licenses for driving big trucks. i might be driving a 1989 Hino SG193, its single axel with air brakes, 6 speed. any info at all would help. thanks.
  • TS323
    • 359
    hmm might of found something saying that air breaks arent the issue. its your GVWR of 26,00 pounds or under and u dont need a CDL. but any other info would be appreciated.
    • mrsleeve
      • Mar 2005
      • 16386
      if its under 26k you would only need a class b with air break endorsement per US DOT rules IIRC. Its been a long while since let CDL lapse so I could be a little off.
      Originally posted by Fusion
      William Pitt-
      • Nygdup
        • Jul 2006
        • 418
        26,000lbs and under no CDL required. Air brakes are irrelevant.
        http://www.fmcsa.dot.gov/registratio...ng/cdl/cdl.htm
        • mrsleeve
          • Mar 2005
          • 16386
          still think you have to have a class B when driving for PAY form 10k-26k
          William Pitt-
          • CabrioPunk
            • 1451
            Negative. Weights determine need for CDL. There are no endorsements without CDL. And even then it isn't an air brake endorsement but there could be an air brake restriction depending on the vehicle he road tests with.
            GVWR 26000 under needs no CDL. He can haul a trailer under 10001 to boot, nothing changes.
            A vehicle with GVWR over 10000 and doing it in this capacity will require a medical certificate with few exceptions.
            • Nygdup
              • Jul 2006
              • 418
              From the website:
              Class B -- Any single vehicle with a GVWR of 26,001 or more pounds, or any such vehicle towing a vehicle not in excess of 10,000 pounds GVWR.
                • 37832
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                • Nygdup
                  • Jul 2006
                  • 418
                  Originally posted by MR 325
                  • mrsleeve
                    • Mar 2005
                    • 16386
                    Originally posted by Nygdup
                    From the website:
                    Ahhh thanks, its been a long while since I have had any dealings with a a CDL personally.
                    William Pitt-
                    • TS323
                      • 359
                      Thanks for all the input guys.
