wireless router passwords....
  • agile30
    • 832
    I have a neighboor that keeps hacking into my system no matter how many times I change the password. I need advice on how to make it secure secure. I only use the basic cisco connection software because I don't know that much about the advance settings.
    Suggestions?
    Originally posted by Good & Tight
    It takes real man to mount a big woman, all you haters are just scared boys.
  • ALYKZANDYR
    • Sep 2009
    • 1336
    I leave mine open, never have any problems, then again i dont live with 6,000 people within 100 feet of me.
    • Jand3rson
      • 37587
      Call Cisco, get their tech support, and explain to them your problem. They'll help you through the advanced settings so you can lock your network down a little more and prevent people from accessing it.
      Cisco customer support phone number, steps for reaching a person, ratings, comments and Cisco customer service news
      • Massimo
        • Jan 2008
        • 3207
        Use letter numbers and symbols. If you have an email with your internet provider change the password on that as well, oh and FB or any other social networks.
        If someone has access to anyone of those then they could obtain your internet password.
        • HR2L
          • 724
          Suggestions?
          Use the Mac Address Filtering feature in Advance Settings. Turn on Mac Address Filtering and only allow the specific Mac Addresses (each wireless device has a Mac Address Unique to it) you want to have access to the wireless router. This is how i kept my ex roommate who was a cheap skate and didn't want to pay for internet from using the wireless feature, even though he knew the wireless password. ;)
          • Stoner Sam23
            • 186
            Does he do bad things with your IP?
            • selturk
              • Dec 2008
              • 1197
              Just change your SSID and hide it.. problem solved :)
              Edit: First make sure you change the default username and password of your router.
              • Kershaw
                • 11822
                change you r password to imagfuckingwaffleswaffleswaffleswaffleswaffleswaffles
                AWD > RWD
                • lambo
                  Captain Scene Points
                  • 10953
                  qft
                  Also, name your network: Hey "Neighbor's Name," Eat a dick!
                  • VinniE30
                    • 2113
                    Use WPA or WPA2. WEP is old and extremely easy to crack.
                    BTW, you don't even have to know much at all to crack WEP keys, there are programs out there that make it extremely easy for even the layman.
                    Zinno '89 <24v swap in progress>
                    • Eric
                      • 5142
                      how do you know when somebody is leaching off your network?
                      • lambo
                        • 10953
                        Check the access list. It should give a list of devices with their Mac Addresses, then cross reference that with your devices.
                        • zig553
                          • Sep 2011
                          • 189
                          If you change your encryption to the highest setting which is WPA2 or even WPA he shouldn't be able to hack through it which can be accessed through the Cisco software through the browser. Though assuming you already have that encryption and he is hacking through it, using MAC address filtering that HR2L suggested might be futile because the hacker might know a work around past filtering AKA changing his MAC address which can be easy to someone who knows what they're doing. Try hiding your SSID I believe there is an option for it in the Cisco software. Also I must stress this part change your Cisco gateway password (the one you use to get to the Cisco interface) and your main router password, use numbers, capitals, symbols and at least 10 characters, doing this would prevent any bruteforce attack (using software to guess multiple combinations of passwords). After all this he might possibly still be able to hack it, but doing this will make his life a living hell attempting so.
                          • HR2L
                            • 724
                            Thats why you set up the filtering process to only allow specific Mac Addresses only, no outside Mac Address (not deny his specific mac address). This will/should work just fine. He can go ahead and change his Mac Address all he wants, as much as he wants, he wont be getting through unless his Mac Address matches one of the ones you allow/listed. Hiding your SSID might also be a good idea as well (2nd measure). I also agree you def. want to set up your network in WPA2 encryption and if you want to be safe, allow it (the router) to self generate a hard password instead of you creating one (it will be far less likely to figured out, as well as brute forced) and just write it down and put it somewhere you wont forget it (if you do, you can always hard reset the router).
                            • Killacortes
                              • 1937
                              Can you ask him how he does it? I would like to do the same at my gym
                              r3v does not fuck around. First you get banned, then they shoot you
