i need TWO M6-1.0X40MM bolts and its 10PM in cali.
  • BlackbirdM3
    • 2773
    Dude, that sucks. You might chase the threads out with a tap. My guess is that it won't do the trick, but it might. Your next choice would be to tap it out to the next larger size. Not a hard job, but one you want to be careful doing. If that fails, your next choice is to helicoil it.
    If you can't get it figured out by Friday afternoon, give me a call and I'll come over and see if we can figure something out. I might be able to help tomorrow, but I think I'm booked.
    Will
    '88 BMW M3
    • Pantless Spency
      It's McRib time!!!
      • Feb 2011
      • 7283
      Will
      if i can't figure it out friday sounds great will.
      im going to take the water pump off and get a better look at the hole it's suppose to be threading into. i think maybe somone stripped it at one point before and now instead of a M6 it might be an M7. so i might give that a little try....
      • BlackbirdM3
        • 2773
        Did you get this figured out or are we working on a water pump this evening?
        Will
        '88 BMW M3
        • Pantless Spency
          It's McRib time!!!
          • Feb 2011
          • 7283
          about to go outside and try some more hardware i picked up at the hardware store...
          will report back soon
          • Pantless Spency
            It's McRib time!!!
            • Feb 2011
            • 7283
            tried everything with no luck, took off the water pump and checked everything out not sure exactly whats going on... :/
            might need to tap one to a 7 and the other to a 9.
            • Pantless Spency
              It's McRib time!!!
              • Feb 2011
              • 7283
              sweet, will (blackbirdm3) came over and we got it all figured out thanks to his skillz, very much appreciated will!
              • Gooch
                • Dec 2006
                • 1674
                What was the problem and solution?
                '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
                '87 535i - Vacuum brake conversion [SOLD]
                '93 525iT - 5-speed swap - 320k and counting
                '09 328xi - 6-speed
                • Pantless Spency
                  It's McRib time!!!
                  • Feb 2011
                  • 7283
                  ^^^ stripped M6 and M8 holes in block where you would fasten the water pump.
                  we re threaded the M8 to an M10 and im going to re thread the M6 to an M7.
                  • BlackbirdM3
                    • 2773
                    Most of the holes were full of crud. One of the M8s was totally lacking threads. I ran the tap all the way down till I couldn't hold it, it caught about 1 thread way down at the bottom. It looks like there had been a bolt that was red loctited in, but all that remained was a little red loctite in the bottom of the hole. The M6 will hold a tap fine, but the threads are chewed down too far for it to allow a bolt to torque down. It would be a perfect candidate for a helicoil, but without pulling the motor out so a drill could be used in a perfect straight line, there is really no way to do those. Taking it out to the next size bolt isn't ideal but it should work fine. All the other bolts tighten up nicely.
                    Will
                    '88 BMW M3
                    • BlackbirdM3
                      • 2773
                      Did you get it put back together today?
                      Will
                      '88 BMW M3
                      • Pantless Spency
                        It's McRib time!!!
                        • Feb 2011
                        • 7283
                        Yup got the water pump fastened just fine with the ultra blue rvt, I will be re assembling it tomorrow. Everything went smoothly! Thanks for the help will.
                        • BlackbirdM3
                          • 2773
                          Good to hear. I figured it wouldn't be a big deal to get it all together.
                          I spent a good 8 hours on the Datsun today, it only looks a little more together than it did yesterday.
                          Will
                          '88 BMW M3
                          • Pantless Spency
                            It's McRib time!!!
                            • Feb 2011
                            • 7283
                            damn....
                            im sure it will be more than worth it once its together though :D
                            • b*saint
                              • 3794
                              Too bad you didn't helicoil it!
                              Ma che cazzo state dicendo? :|
                              • Pantless Spency
                                It's McRib time!!!
                                • Feb 2011
                                • 7283
                                we were thinking of going that way but it was a tight space and lateral not vertical, helicoil would have been hard to pull off to say the least.
