Old-School Air Compressor Rebuild
  • AndrewBird
    The Mad Scientist
    • 11898
    A while back I bought an old air compressor that was built into a shopping cart. The compressor pump I later found out is from an AC unit from the 60's (from what I can tell). Very heavy built, made in USA. All the gaskets were made from lead.
    The very dirty air "filter".
    My design inspiration.
    Ended up sandblasting everything after disassembly. Drew up new gaskets in AutoCAD and cut them out on my vinyl plotter out of gasket paper (the paper in the picture is just normal paper used for testing).
    Gave everything a heavy coat of paint. Used ACE Hardware rust reformer.
    Brass parts were all very dirty and painted black.
    After paint stripper.
    A little polishing and clear coat.
    Cut out a piece of 1/8" steel on the waterjet at work. Had a coworker bend it up on the CNC brake. I welded nuts on the underside of the holes for everything to bolt to.
    Flywheel has just enough clearance.
    Copper tubing from the pump to the tank.
    Tank sandblasted. It's an old water softener tank, about 15 gallons.
    Rear axle welded on. Metal is from the shopping cart.
    Ends are threaded for a bolt.
    Everything welded up ready for paint. You can see how I used the shopping cart wheels for the back. The front "foot" is a piece of u-shaped tubing out of the scrap bin at work. The handle is the original shopping cart handling with a section cut out of the middle to make it narrower.
    Using the shopping cart "grill" as a pulley guard. Mocked up here.
    Just enough room.
    Upper mount made from angle iron and aluminum tubing.
    Final assembly.
    A little bit of gold pin striping.
    Still need to order a pressure switch for the motor and buy a regulator/filter. Also going to add a check valve on the input to the tank. Found one that is both a check valve and pressure release for the compressor, so it doesn't have to start with pressure pushing on it.
    The best part about it is it is REALLY quite. Standing next to it, two people can have a conversation without having to raise their voice.
  • Danny
    • 14216
    I've been following this on Facebook. Awesome final product.
    • rturbo 930
      • Dec 2005
      • 2625
      Sub'd. My dad has one or two old compressors - think they used to be part of an old fridge? We don't used it as a compressor anymore, so they're just sitting around. Thanks for the idea.
      • Nsquared97
        • 1656
        This is seriously cool. Great work!
        • E30_Pare
          • 7801
          Sweet. I use an old compressor in my garage that my pops picked up from a garage sale. Works awesome and not as loud as our OilFree craftsman that rattles your teeth out.
          DREWLIENTE
          1$ PShops PM me
          • BillBrasky
            • Dec 2008
            • 1641
            Nice job! I really need to get a cnc brake for my shop.
            • slammin.e28
              שמע ישראל
              • 12054
              That is spectacular!
              Now I want to dig an old compressor out of somewhere.
              • ANDRÜ
                • 1020
                So cool! Looks great
                • E30_Pare
                  • 7801
                  Did some research on my compressor. Its a Campbell-Hausfeld rebranded by Sears. I think its at least 40 yrs old. Cranks out some pretty decent CFM for its size.
                  DREWLIENTE
                  1$ PShops PM me
