Subaru transmission help
  • F34R
    sLaughter
    • 12376
    I posted on Nasioc to see if anyone knows, I do know we have a good bit of Subaru gurus on here, any help for gearing ratios that will work would be a big help.
    I bought a 96 Outback Legacy for a winter car and it has a bad Automatic transmission**popped the pan off and tons of broken metal came out**
    Transmission I have is: TZ102Z2ABA
    I found a handful of transmissions in the junk yard and looked at the coding from a site someone posted about a Gen 2:
    Post #5
    Here is what I can get for my car in the local junkyard(starting with most matching):
    TZ102Z2DBA
    TZ102ZA3BA
    TZ102ZA5AA
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
  • F34R
    sLaughter
    • 12376
    Pretty sure I answered my own questions
    So I put all the numbers side by side and entered them into the code, I was confused by the last 3 letters/numbers.
    Looks like since this is a Gen 2 list break down, the only thing that REALLY matters to me is the first 6 digits:
    I entered my coding down the list till B = Correlating engine classification Since this is a chart for a Gen 2 that would mean that would be different vs mine? All the important numbers match for gearing etc
    example code = t z 1 0 2 z 2 d b a
    t z 1 0 2 z 2 a b a
    Breakdown:
    T = Transmission symbol
    (T - Transmission)
    Z = Transmission associated classification
    (A - 2WD AT)
    (M - 2WD MT)
    (Y - 4WD AT)
    (Z - 4WD AT)
    10 = Transmission type series classification
    (75 - MT [75mm])
    (10 - AT [108mm])
    2 = Car body series
    (2 - Legacy series)
    Z = Standard transmission spec classification
    (A - 2WD AT [TA102])
    (R - 2WD MT [TM752])
    (V - ViS-C center diff 4WD [TY752])
    (Y - VTD MP-T center diff 4WD 4AT [TZ102])
    (Z - MP-T center diff 4WD 4AT [TZ102])
    (X - ViS-C center diff 4WD D/R [TY752])
    (B - 2.0L DOHC MPi turbo)
    (D - 2.0L DOHC MPi NA)
    (S - 2.0L SOHC MPi NA)
    (W - 1.8L SOHC MPi NA)
    (1 - 2.5L DOHC MPi NA)
    C = Yearly improvment/design change classification
    (Starts with 'A' and subsequently 'B', 'C', etc.)
    A = Shows change in specification in transmission body
    ('A', 'B', 'C', etc.)
    A = Doesn't change based on vehicle engine or body
    Current cars:
    ~ '87 535
    ~ '06 X5 4.8is
    • Kevinl
      • Oct 2012
      • 897
      A 4eat is pretty much the same the later ones had spin on filters the outbacks had 4.44 gearing so you will want one with the same gearing i used to have a svx and put a outback 4eat and changed the rear diff to match
      1989 BMW 325is Lachsilber metallic 5 speed
      2007 BMW 335i KARMESINROT 6 Speed manual
      2011 BMW X5 35I
      • flyboyx
        • 8371
        there was a '96 legacy outback with a manual trans car in the local pick a part. when i was there yesterday, someone had pulled the trans and engine out of the car to take the clutch disk and pressure plate. the rest was sitting in front of the car. i suppose that would solve your problems.
        Gigitty Gigitty!!!!
        • quikveedb2
          • Sep 2007
          • 2258
          Hey another Subaru owner! Mine is my winter beater as well, '97 Legacy L manual. I don't have much info to offer since I'm relatively new to Subies, but I can suggest USMB as a resource. I've used the forum since I got mine & it's content and members have been helpful thus far; Ultimate Subaru
          You know why you're drinking that Pabst? No its probably not because it was the first beer you grabbed. It's because you're a winner.
          • BobombETA
            • Apr 2008
            • 1575
            Thanks for the heads up on the forum, I just joined. I'm a recent subaru owner myself so I'm still feeling it out. I purchased a 2000 Outback Limited Wagon for the winter. 182,000 miles but completely rust free.
            Instagram
            Current: 99 M3
            Past: 84 325e, 84 528e
            • Roysneon
              • 4505
              I work parts at a Subaru dealership part time, I may be able to help you out on Saturday. I can probably at least tell you the gear ratios.
              Originally posted by mbonanni
              I am a pursit now.
              • F34R
                sLaughter
                • 12376
                Thanks, Roy check the ratios between the transmission I have right now and the first replacement code in that list. I can get the diff if I want to match ratios, I am pretty sure they should be roughly the same.
                Current cars:
                ~ '87 535
                ~ '06 X5 4.8is
