What would you use for a seized Coilover adjuster?
  • Klug
    • Sep 2011
    • 804
    Hey guys-
    Just wanted to see what you guys thought about this situation I'm in. I'm starting to part back my 2008 Audi A4 (thank god) and I'm trying to sell my Koni coilovers that were on for about 30k. Suspension swap was done- but I cannot for the life of me get this one collar around the coilover to budge. I was able to get the locking collar off, but striking out with the adjuster.
    1) Tried PB Blaster - FAILED
    2) Tried using Kroil- which apparently is the "God of all Gods" when it comes to seized parts and $25/can - FAILED
    3) Tried soaking the entire collar in ATF+Acetone overnight, which broke free the other coilover that was seized but not on this one - FAILED
    I am avoiding using heat since the strut is gas filled and don't think its the best bet.
    I'm striking out here, sucks since I can really only get this to crack with the stupid coilover wrenches which are garbage. I tried a chain-wrench also with no luck (mainly I can't get it in a good spot to hold)
    If all else fails here, I'm going to cut it off and order replacement collar from Koni- but I'd rather not since I'm trying to sell these ASAP. And I'm asking here since the Audi forums nerds are all buttholes.
    What would you do?
    555Garage - Kingston, PA
    '13 BMW e70 X5 35d
    '95 BMW e34 525i
    '92 BMW e30 325i S52 Vert (Quade the Vert)
    '92 Range Rover Classic
    '90 Range Rover Classic
    '89 BMW e30 325i Coupe (The DIRTY30)
    '81 VW MK1 Rabbit Caddy Diesel
    '76 Honda CB550K Cafe/Brat
    '67 Pontiac LeMans
    '24 Model T Depot Hack
    ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
  • kickinindian
    • 2327
    i would say just cut it and order a new one not worth the hastle just cut it most of the way and use a screwdriver or chisel and pop it apart.
    • IronFreak
      • Dec 2012
      • 3702
      Pee on it.
      Instagram @rebellionforge
      • ButtJuice
        • Dec 2009
        • 2609
        Hammer.
        1991 318is - Sold
        1986 325 - Sold
        Instagram - Lamoursum
        • BraveUlysses
          • Jun 2007
          • 3781
          i would still try heat and be careful to focus most of it on the collar. if not cut it off
          • ajhostetter
            • Apr 2013
            • 1218
            I had this happen on my Volvo. You need to mind-fuck the hell out of that strut. But seriously...judicious use of heat is in order
            2014 GTI | 2002 Land Cruiser | 1991 Volvo 745t
            • slammin.e28
              שמע ישראל
              • 12054
              Large pipewrench.
              • IronFreak
                • Dec 2012
                • 3702
                Blunt told me Slammin is pretty damn tight, drop him on that collar and give it a spin. It's all about that leverage.
                • cale
                  • Oct 2005
                  • 2331
                  There's a good chance there's something stuck in the threads, pretty common for people to adjust them without cleaning them 100%. Cut it off and replace it, not worth fucking up the threads on the body.
                  • ak-
                    • 12422
                    Yeah there's probably grains of sand in between the threads itself. See if the collar can be ordered separate then just cut it off.
                    1991 325iS turbo
                    • acolella76
                      • 2950
                      Try heating it before cutting it off. Just enough to get the adjuster hot, the strut can take some heat but don't go overboard. Maybe use some kroil too. If it doesn't seem like it wants to budge then screw it and buy a new one
                      -Alex
                      • TurboJake
                        • 3780
                        Heat. the aluminum will absorb it VERY fast, and the ss tube and strut won't absorb nearly as quickly. Don't hold heat to it too long. Nice and evenly.
                        Easy fix.
                        Leave Me Transaction Feedback
                        • Northern
                          I like cupcakes & sh!tboxes
                          • 5237
                          I'd go with heat. Wrap the area immediately next to the collar with some sort of insulation (Scotchbrite pad with aluminum tape covering it is my go-to) then stick it in the freezer for a few hours (or overnight).
                          Hit just the collar with a heat gun, or lightly with a propane torch to try to create enough of a difference to get it loose.
                          I've done shit like this at work, but mostly for trying to expand a fitting and shrink a plug/bushing for installation. It may be too seized/corroded or whatever, but it is worth a shot.
                          Originally posted by priapism
                          Originally posted by shameson
                          • GT BMW E30
                            • Nov 2008
                            • 2491
                            Pipe wrench and maybe an extended pipe on the end. Vice grip one end.
                            • Klug
                              • Sep 2011
                              • 804
                              Thanks for all the inputs- I tried using heat today but that didn't seem to help out. It did however, boil the solvents out of the threads- which I thought it was doing something. But it didn't so I grabbed the dremel and got at it. Luckily- I didn't knick any threads. Wrapped the bad boy with some towels and got it off.
                              From the pics- it looked like all my solvents only really got through the first three threads. I'm guessing since it is such a tight seal, the solvents probably have to flow through one thread at a time.
                              Anyway- now off to buy the $50 replacement from Koni and sell these stupid things.
                              '13 BMW e70 X5 35d
                              '95 BMW e34 525i
                              '67 Pontiac LeMans
