This Is Pictures.
  • slammin.e28
    שמע ישראל
    • 12054
    #20731
    • Fusion
      • Nov 2009
      • 3659
      #20732
      Best UFO sighting ever
      • Pantless Spency
        It's McRib time!!!
        • Feb 2011
        • 7283
        #20733
        aw man,
        thats one of my facvorite drift cars evar :P
        • riverdale21
          • Mar 2004
          • 786
          #20734
          19 hour workday converting an analog 70's Cat generator to digital control. Located in Westminster, SC.
          Rats nest of engine wiring. The engine harness was so chopped up and spliced it was decided to re-wire everything.
          Aaaaaaaaand many hours later... The black wire wrap is the new harness. Simplified the wiring by installing a new coolant temp sensor and oil pressure sensor. All new wiring to the existing governor control motor and fuel stop solenoid. Wound up reusing the mag pickup wires just rerouting behind the engine straight to the control panel. Wire used is industrial double insulated with braided steel line in between the two layers of insulation.
          Sorry about the poor quality of the after pictures, it was pretty dark by the time the job was done.
          This would be like installing an Electromotive TEC3 on a BMW 2002. It's cool tuning an old diesel with a laptop.
          Since this generator is not just used for a stand-by emergency application but also for peak shaving (they run it time to time as their prime power source to save the city government money on the utility bill) it has to pass Tier 4 emissions by 2013. Stand-by only units will be grandfathered into the new emissions standards and will be exempt.
          By installing this digital controller we can get them a little bit closer. Phase two will be to test a Diesel Particulate Filter on the exhaust or a diesel catalyst. If neither of those systems work or aren't deemed fiscally possible we will be installing an entire new unit complete with automatic transfer switch so the unit will come online and transfer from utility to generator automatically in a power outage. Right now they are doing everything manually. Would you want to flip a switch that has 4,160V going through it in a thunderstorm?
          • Stanley Rockafella
            • Aug 2011
            • 4061
            #20735
            way to go Macgyver!
            • J3M93
              • 448
              #20736
              YES
              • Nsquared97
                • 1656
                #20737
                Dat Datsun...!
                • e30Villain
                  • Jun 2012
                  • 540
                  #20738
                  87 ETA | Hibernating
                  • Pac1373
                    • 1746
                    #20739
                    Originally posted by J3M93
                    YES
                    Thanks for that, I need some alone time now.
                    Originally Posted by ACMF74
                    i clicked on this cuz i saw p3nis
                    • J3M93
                      • 448
                      #20740
                      • FunfGan
                        • Jan 2011
                        • 4958
                        #20741
                        Bloody hell.
                        Go here be happy!
                        Ratchet Garage e30 V8 build.
                        • Fusion
                          • Nov 2009
                          • 3659
                          #20742
                          Jeeeezus fuuuuuuuuuuuck!
                          • BlackbirdM3
                            • 2771
                            #20743
                            Its cool but only if its got a turbo L series in it. I'm guessing its a modern motor which makes the car a POS and a total waste of a car. Vintage cars do not need modern motors. They aren't modern and installing a modern motor does nothing but eff it up. The motor makes the car. Its sad, it will cost more to fix the car by ditching the modern motor than the car will be worth. There is nothing that irritates me more than seeing a modern motor in a vintage car. It doesn't matter what sort of car it is.
                            Will
                            '88 BMW M3
                            • CHIF8008
                              • 3447
                              #20744
                              sad story^ b28 swap in my bros e21 was the best driving experience i have ever had.
                              so all the 24 valve guys here have POS's? or are you, "e30 not vintage" HMM HMM
                              -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
                              -The Beauty in the Tragedy-
                              MECHANIC SMASH!!- (you all know you do it)
                              Got Drop?? ;-)
                              But of course
                              E30s are know to be notoriously really really really ridiculously good looking
                              • Pantless Spency
                                It's McRib time!!!
                                • Feb 2011
                                • 7283
                                #20745
                                hoping to have a 1uz in my e21 :devil:
