2.0 liter motor w/9.0 compression
E-12 head ported and flowed
292 Schrick cam
tii distributor w/Pertronix and MSD 6A ignition
Head studs
Baffled oil pan
E-30 M3 starter
E-30 M3 radiator
1 5/8” Top End tubing header w/2 ¼” tubing exhaust
Resonator and rear muffler from Top End Engineering
Motor built by Eric Kerman(EDK Motors). Compression in all cylinders is 160 lbs. or higher. Camden roots-type supercharger with one 45mm Weber side draft carburetor generates approx. 10lbs. of boost (MSD Boost Sensor allows motor to run on 93 octane pump gas). Approx output 200+ HP. A 1981 320iS 5 speed overdrive transmission w/E-30 325 clutch package is installed along with a 320iS 3.90:1 limited slip differential. Ireland Engineering short shift kit actuates the transmission and all components used in the 5-speed conversion are BMW factory parts.
